Faulty CD Changer??.....
oDUTCHYo
Hi,
Went to put a CD on from MMI today, its said there was a fault???!!!...
I opened the glovebox and a CD was half out and all the lights where flashing off and on!!??
I cant eject or load either, does ANYONE know how to reset the cd changer? - Do I have to unplug it? - if so, how do I take out the cd changer....confused.gifconfused.gifconfused.gif
thanks,
  • 3 weeks later...
As Dutcy said in post #4, take the side panel off on the passengers side glovebox, (got a small round vent at the top) and it will expose the fuses. On the Side panel is a matrix that shows what fuses do what. It will be clearly marked "Communications) There are three fuse holders, Red, Black and Brown.
Hi, i have the same problem on my audi a6 2005 with the 6 cd-changer, it displays CD fault and the lights are flashing on the cd changer. Could you upload a photo. what exact fuse did you unplugged and where is the fuse box located? Thanks in advance
