Intake Manifold Runner
gadgetmind
Audi A8 D3 3.0 Tdi Quattro with 75800 miles (122000km) has just put its Check Engine Light on. It's running fine other than that.
Vagcom shows -
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 402 E HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0010
Revision: --H03--- Serial number: AUX3Z0F6399819
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 1E38CA19C9CB36E8330
2 Faults Found:
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 21
Mileage: 116632 km
Time Indication: 0
Date: 2012.11.10
Time: 16:35:36
Freeze Frame:
RPM: 714 /min
Torque: 93.6 Nm
Speed: 0.0 km/h
Voltage: 13.91 V
Duty Cycle: 80.9 %
Duty Cycle: 89.2 %
Duty Cycle: 80.9 %
012597 - Intake Manifold Runner Control
P3135 - 001 - Lower Stop not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 9
Mileage: 116691 km
Time Indication: 0
Date: 2012.11.12
Time: 09:28:26
Freeze Frame:
RPM: 798 /min
Torque: 156.0 Nm
Speed: 0.0 km/h
Voltage: 14.06 V
Duty Cycle: 88.8 %
Duty Cycle: 89.2 %
Duty Cycle: 80.9 %
Readiness: 0 1 0 0 0
The only other errors are -
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
01598 - Drive Battery Voltage
and loads of these -
02277 - Quiescent Current Stage 6
000 - - - Intermittent
I suspect those at the end are because my battery is close to EOL as it goes down to 10% after sitting for an hour with ignition off but radio on.
Googling suggests the Intake Manifold Runner ones are probably due to the linkage going slack between the motor and the flap. Are there any cheap and easy fixes for this one?
Thanks
I've just ordered a pair of these.
Inlet / Intake Manifold Swirl Flap Repair Kit Audi VW 2.7 3.0 Tdi V6 Q7 A4 A5... | eBay
People say that the flap and its hinge can get gummed up, but given this error is so intermittent for me, I think it's more likely just this actuator. Anyway, I might get them for this weekend so can spend a chilly day in our garage!
Yeah, was a bout to say 'swirl flaps'!
Grab the PDF and it would be good to shove it on this thread if you would be so kind............
So far, mine isn't reporting any issues, but I've read elsewhere that cleaning it usually helps, as does fitting some washers somewhere or other?
My battery sits at 10% too, not sure if it's the battery or if it's the software - as many reports say the software isn't good at reporting battery life and later versions of the MMI don't have that feature?
The PDF is regards removing manifolds, which isn't usually required. I'd post but it's probably copyright someone or other, though two different ebay vendors sent me the very same document so I suspect it's already seen as open source!
As for swirl flaps being required, I'm not sure. BMW owners seem to remove the ASAP before the fall to bits and eat turbos, but the Audi ones just seem to throw error codes. I can cope with the odd code with CEL is annoying so I'll fix it.
OK, job done. The new parts are much better made than the Audi ones and the fault codes have gone. Let's hope they stay that way!
The job is a doddle on the near side and a bit of a b1tch on the offside. For the latter, access is very limited and removing and refitting the clip is *much* harder as it's upside down. A few cloths rammed into gaps to prevent dropped bits heading south and lots of patience is all the advice I can really give. Removing a section of intake would have helped a little. but one end was reluctant and I didn't want to risk damaging it.
Next problem - battery goes from 100% to 10% in just a few minutes of using the vagcom lead, which suggests that that too needs swapping. I'll probably get someone to do that to save all the hassle of losing settings and coding in the new one.
