Enabling headlight lamp in Instrument cluster
Phil1978
Does anybody on here know if it is possible to enable the little green headlight lamp in the instrument cluster when the lights are switched on, either sidelight or dipped beam. Just that it doesn't light up as my previous B6 did, all that lights up is the sidelight light on the light switch (it goes from red to green).
The car is a 2007 A4 Cabriolet with auto lights and Xenon headlights.
Thanks in advance. . . . . .
hmmmmmm
Thanks Terry, so is this a common B7 thing???
Oh and by the way, stick with a chrome surround Terry, it looks sooo much better.
I tried a RS4 black optic before I went for the RS4 chrome, and the chrome looks much better in my opinion, especially if you have the chrome window surrounds on a black car.
Done the output tests and no lamp for the lights lit up . . . . . .hmmmm
Still not convinced I had to delve deep . . . ooh er . . . And found a thread on a german site. And on further looking on VAG-COM found where you can activate the lamp from.
Yippee, it now shows in the instrument cluster.
Sorry, thought I'd added the link :
Go to the Instrument Cluster module (17)
Make a note of the coding
-2 form the coding in the ?? part - 00??xxx
Mine was 0006411 , recoded to 0004411 and voila the instrument cluster sidelight lamp lights up.
Hope this helps.
You decided what you are going to do with the front grill yet Terry???
Hope this helps.
My coding was 0023401 and it's now 0021401
Daz,
My coding was exactly the same as Phils, I think yours was different as you have an RS4 and will have the value entered for the smaller fuel tank and for the switch in the clutch pedal as you have to depress it for the engine start button.
Thats what I reckon anyway, could be wrong!
DAZ . . . . Are you CRAZY . . . . Why is your seatbelt warning turned off???? Did you turn it off or was it like that from Audi.
I know people dont always wear their seatbelts, and I have seen the aftermath enough times to know why they are fitted, but even so, especially in a cabriolet!!!
