Daz Posted October 1, 2007 Report Share Posted October 1, 2007 Please add to this list any useful VAG COM codings you find / use. Please keep this thread purely for the codings and create an new thread to discuss them Enabling headlight lamp in Instrument cluster Audi A4 B7 Go to the Instrument Cluster module (17) Make a note of the coding -2 form the coding in the ?? part - 00??xxx Mine was 0006411 , recoded to 0004411 and voila the instrument cluster sidelight lamp lights up. Wiper system mods on the B7 A4 B7 Just been mucking about with this but anyone know what the speed related wipe does and if it works?.. I assume the drop tear is like the B6 used to be with a delayed wipe after a wash wipe. (Couldnt get any of them to work by the way!) My std value was 115 on both the a4 and the rs4 Adaptation ch13 on central elec.. Channel 013: Wiper Setup Standard: 115 +001 = Speed Reset +002 = Short to Plus Monitoring +004 = Rain Sensor active +008 = Long Post Wiping after Washing (Drop/Tear Wiping) +016 = Speed dependent Wiper interval active +032 = Headlight Washer System active +064 = Reverse Gear Wiping active Xenon Headlight adjustment for Europe Adaptation Channel 10 of the Xenon Headlamp Range Control module (address 55), it's called "Tourist Option". Set this to 1 (it's normally 0) and you will have headlights that no longer dip to the left. DVD Eject Button functionality on RNS-E The RNS-E can be setup (using adaptation channel 67) to disable the DVD eject button (as an anti-theft feature). 0 = Button enabled 1 = eject 255 = Button disabled 8P A3 Removing/Adding DRL's [select] [09 - Cent. Elect.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Uncheck/check the box for "Daytime driving lights (North America)" 8P A3 Changing honk/flash behavior when alarm is disarmed [select] [46 - Cent. Conv.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Check or uncheck the box for "Locking Confirmation (Horn) via Remote Control" Check or uncheck the box for "Locking Confirmation (Blink) via Remote Control" Check or uncheck the box for "Unlocking Confirmation (Horn) via Remote Control" Check or uncheck the box for "Unlocking Confirmation (Blink) via Remote Control" [Transfer Coding] 8P A3 Operating Windows and Sunroof with Remote (Note, the sunroof cannot be opened with the remote) You need to continuously hold the remote button for the function to operate. [select] [46 - Cent. Conv.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Uncheck the box for "Comfort function power windows/sunroof via remote control inactive" Check the box for "Comfort opening power windows via remote control active" Check the box for "Comfort closing power windows via remote control active" Check the box for "Closing sunroof via remote control active" [Transfer Coding] Link to comment Share on other sites More sharing options...
Daz Posted October 1, 2007 Author Report Share Posted October 1, 2007 Here's one from Phil1978 Enabling headlight lamp in Instrument cluster Audi A4 B7 Go to the Instrument Cluster module (17) Make a note of the coding -2 form the coding in the ?? part - 00??xxx Mine was 0006411 , recoded to 0004411 and voila the instrument cluster sidelight lamp lights up. Link to comment Share on other sites More sharing options...
Daz Posted October 1, 2007 Author Report Share Posted October 1, 2007 One from the911sc Wiper system mods on the B7 A4 B7 Just been mucking about with this but anyone know what the speed related wipe does and if it works?.. I assume the drop tear is like the B6 used to be with a delayed wipe after a wash wipe. (Couldnt get any of them to work by the way!) My std value was 115 on both the a4 and the rs4 Adaptation ch13 on central elec.. Channel 013: Wiper Setup Standard: 115 +001 = Speed Reset +002 = Short to Plus Monitoring +004 = Rain Sensor active +008 = Long Post Wiping after Washing (Drop/Tear Wiping) +016 = Speed dependent Wiper interval active +032 = Headlight Washer System active +064 = Reverse Gear Wiping active Link to comment Share on other sites More sharing options...
the911sc Posted October 2, 2007 Report Share Posted October 2, 2007 Link to comment Share on other sites More sharing options...
seansimpson Posted October 20, 2007 Report Share Posted October 20, 2007 Xenon Headlight adjustment for Europe Adaptation Channel 10 of the Xenon Headlamp Range Control module (address 55), it's called "Tourist Option". Set this to 1 (it's normally 0) and you will have headlights that no longer dip to the left. Pretty sure I got this from a thread here somewhere...the words are verbatim Link to comment Share on other sites More sharing options...
seansimpson Posted October 20, 2007 Report Share Posted October 20, 2007 DVD Eject Button functionality on RNS-E The RNS-E can be setup (using adaptation channel 67) to disable the DVD eject button (as an anti-theft feature). 0 = Button enabled 1 = eject 255 = Button disabled Again credit goes to a mystery person on a thread somewhere on this forum Link to comment Share on other sites More sharing options...
livall Posted October 20, 2007 Report Share Posted October 20, 2007 8P A3 Removing/Adding DRL's [select] [09 - Cent. Elect.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Uncheck/check the box for "Daytime driving lights (North America)" [Transfer Coding] [Do It!] Link to comment Share on other sites More sharing options...
livall Posted October 20, 2007 Report Share Posted October 20, 2007 8P A3 Changing honk/flash behavior when alarm is disarmed [select] [46 - Cent. Conv.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Check or uncheck the box for "Locking Confirmation (Horn) via Remote Control" Check or uncheck the box for "Locking Confirmation (Blink) via Remote Control" Check or uncheck the box for "Unlocking Confirmation (Horn) via Remote Control" Check or uncheck the box for "Unlocking Confirmation (Blink) via Remote Control" [Transfer Coding] [Do It!] Link to comment Share on other sites More sharing options...
livall Posted October 20, 2007 Report Share Posted October 20, 2007 8P A3 Operating Windows and Sunroof with Remote (Note, the sunroof cannot be opened with the remote) You need to continuously hold the remote button for the function to operate. [select] [46 - Cent. Conv.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Uncheck the box for "Comfort function power windows/sunroof via remote control inactive" Check the box for "Comfort opening power windows via remote control active" Check the box for "Comfort closing power windows via remote control active" Check the box for "Closing sunroof via remote control active" [Transfer Coding] [Do It!] Link to comment Share on other sites More sharing options...
allan1970 Posted August 11, 2008 Report Share Posted August 11, 2008 hi do you know anyone in the northeast that could programme my retro fit cruise controll on a 2007 b7 audi avant. all work done just needs vagcom Link to comment Share on other sites More sharing options...
Rustynuts Posted August 11, 2008 Report Share Posted August 11, 2008 Whereabouts in Northeast?:D Link to comment Share on other sites More sharing options...
andyrhicks Posted January 30, 2009 Report Share Posted January 30, 2009 Anyone know any one in France with this technology? Am near St Nazaire. Link to comment Share on other sites More sharing options...
IceMan83 Posted May 5, 2009 Report Share Posted May 5, 2009 8P A3Removing/Adding DRL's [select] [09 - Cent. Elect.] [Long Coding - 07] [Long Coding Helper] Click on each of the Byte numbers in step 3) and you'll see the selectable options below. Uncheck/check the box for "Daytime driving lights (North America)" [Transfer Coding] [Do It!] I have A3 8P with BiXenon and daytime lights DRL and now I am wondering if it would possible to activate additionally Running/Tail/License Plate Lights. I'm from Poland and our law force us to use DRL with running tail lights and licence plate. If you have any ideas I would be very gratefull Link to comment Share on other sites More sharing options...
PetrolDave Posted May 6, 2009 Report Share Posted May 6, 2009 Not sure if this link will help? de.openobd.org - audi - a3 (8p) Link to comment Share on other sites More sharing options...
IceMan83 Posted May 6, 2009 Report Share Posted May 6, 2009 I saw this site earlier but it is better than nothing Thanks I am waiting for other ideas. Link to comment Share on other sites More sharing options...
