Chipped tooth..
Hopsta
Depends how bad the chip is. If you have just taken a corner off then they will probably take the filling out and re-fill the tooth incorporating rebuilding the side.
If you've taken a big chunk out then you are best off having a crown. As the guys said circa £300 to £400 for a porcelain job which would be private - can't get porcelain on the NHS anymore, just gold.
If the tooth is a rear molar that can't really be seen then I would suggest going for a gold crown - it's cheaper (£160), lasts longer and is kinder to your mouth. My lower left 8 molar (the very back one) has a gold crown which no-one ever sees and it is very well behaved.
  • 3 months later...
