AB Foam Gun
spikeyboy
Realise this topic has been discussed a fair bit of late, following the various threads i decided to upgrade my Kracher Foam gun to the AB foam gun,
Received through the post yesterday and have a couple of questions:
1) My understanding from previous threads is that you turn the black dail to "negative" to increase the amount of foam - is this correct ?
2) What is the best setting for the actual nozzel - should the reads be closed or open ?
Hoping to have a play over the weekend.
Thanks
1) the symbol on the dial is like a volume indicator for want of a better decription. At the thin end it draws in less mix, at the fat end, lots...
2) Reed open is more or less a straight jet. Reed closed fans out in an almost 180 degree arc. Again just tinker a bit and you find what works best.
Oh, and don't drop the fecking thing or the end flies off and you lose a brass pin and end up using duct tape to keep it together. frown.gif
I've only recently bought one of these. I find it works best with the knob fully to the negative position. This makes the foam a little thicker and clings to the car better / longer.
You need to adjust the spray nozzle as it can come out at a very wide angle. You can make it a nice narrow spray for getting into the wheel arches.
