Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 was just wondering if it would be just as easy to replace the loom inside door? the problem i have with mine is that its snapped nearer the door end which is making it even more difficult to get at as its inside the rubber boot Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 question, are there sensors in the door for the airbags? should i be disconnecting the battery before I attempt anymore? Link to comment Share on other sites More sharing options...
paul_tdi Posted March 4, 2008 Report Share Posted March 4, 2008 I think the loom is about £100! Dont know about airbag sensors, ipretty certain they are located in the B Pillar. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] I think the loom is about £100! Dont know about airbag sensors, ipretty certain they are located in the B Pillar. [/ QUOTE ] If the loom is £100 its still better than there diag fee, now ive got the door panel off i maybe able to get this one out and try and repair that way, the rubber housing is a pain wonder if anyone would know the part number Link to comment Share on other sites More sharing options...
paul_tdi Posted March 4, 2008 Report Share Posted March 4, 2008 8E0 971 029 with a postfix of C or N depending on chassis number. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] 8E0 971 029 with a postfix of C or N depending on chassis number. [/ QUOTE ] Many thanks for that. Link to comment Share on other sites More sharing options...
paul_tdi Posted March 4, 2008 Report Share Posted March 4, 2008 No worries! There appears to be a coupling repair harness listed also which may be cheaper? Not sure it it is suitable but certainly worth asking: 8Z0 971 029 L. Will be interested to see how you get on. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] No worries! There appears to be a coupling repair harness listed also which may be cheaper? Not sure it it is suitable but certainly worth asking: 8Z0 971 029 L. Will be interested to see how you get on. [/ QUOTE ] thanks again, ill be heading up to the dealers tomorrow will let you know Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 sorry to keep asking but any idea how to remove the plug from the car side, seemed a little tricky, if i can do that might be worth trying to fix the wires first. Link to comment Share on other sites More sharing options...
paul_tdi Posted March 4, 2008 Report Share Posted March 4, 2008 Not sure TBH mate, may have to access from behind the footwell trim, will have a butchers to see what I can find out! Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 4, 2008 Author Report Share Posted March 4, 2008 [ QUOTE ] Not sure TBH mate, may have to access from behind the footwell trim, will have a butchers to see what I can find out! [/ QUOTE ] Cool, do you have access to all the part numbers by any chnace? Link to comment Share on other sites More sharing options...
shark_90 Posted March 4, 2008 Report Share Posted March 4, 2008 [ QUOTE ] Same happened on mine, it was exactly the same wire as previously mentioned! It is do-able but as Shark has commented a lot better if you get 2 on the job. I actually soldered another bit of wire on rather than just try and join the two pieces. At least this way you can fix to the exposed wire, thread back thourgh the rubber tubing, trim as required and then attach to the other end.Good luck! [/ QUOTE ] Ah yes, come to think of it, that's what I did. Trouble is I did it about 30 mins before going out on a rather heavy night, but it's all flooding back now Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 5, 2008 Author Report Share Posted March 5, 2008 [ QUOTE ] [ QUOTE ] Same happened on mine, it was exactly the same wire as previously mentioned! It is do-able but as Shark has commented a lot better if you get 2 on the job. I actually soldered another bit of wire on rather than just try and join the two pieces. At least this way you can fix to the exposed wire, thread back thourgh the rubber tubing, trim as required and then attach to the other end.Good luck! [/ QUOTE ] Ah yes, come to think of it, that's what I did. Trouble is I did it about 30 mins before going out on a rather heavy night, but it's all flooding back now [/ QUOTE ] LOL! Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 5, 2008 Author Report Share Posted March 5, 2008 got it to a point now where I can probably try and repair the connection, and on closer inspection there appears to be another one cut too. Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 5, 2008 Author Report Share Posted March 5, 2008 certainly would make life a lot easier if I could get the plug out Link to comment Share on other sites More sharing options...
shark_90 Posted March 5, 2008 Report Share Posted March 5, 2008 Just strip a bit of wire back with a stanley knife blade and solder another piece of wire in there to join the two. Same for the other wire if there's 2 broken. Dead easy! Link to comment Share on other sites More sharing options...
Bradmax57 Posted March 5, 2008 Author Report Share Posted March 5, 2008 weyhey!!!!!!!!1 it works, one shot doesnt seem to but the rest does Link to comment Share on other sites More sharing options...
paul_tdi Posted March 5, 2008 Report Share Posted March 5, 2008 Try lowering the window all the way and then back up again. Sometimes they need resetting. I may be able to help with other part numbers if required! Paul Link to comment Share on other sites More sharing options...
PetrolDave Posted March 5, 2008 Report Share Posted March 5, 2008 [ QUOTE ] Try lowering the window all the way and then back up again. Sometimes they need resetting. [/ QUOTE ] Hold the switch down for about 5 seconds once the window has reached the bottom - that's what's needed to reset the one touch. Link to comment Share on other sites More sharing options...
