Changing Bi-Xenon headlights for driving in Europe
h5djr
I have just received my VAG-COM cable from Ross-Tech in the States. I've loaded the spftware onto my laptop ok and connected up to the ODB port and run a full Auto-Scan. All seems to work as it should.
All I need know is to know how to recode my Bi-Xenon headlights for driving in Europe. Anyone know how to do this or where I can the information.
I don't have adaptive Xenons by I had mine 'done' at my dealer last year. They said they have to connect it to their VAG5051 system and change a code. After they had done it a reminder to have them changed back was given on the DIS whenever the ignition was turned on.
So I assume it must be possible with VAG-COM as well.
Hi Sebastian
The part number of the module(#55) is 8P0-907-357C
Here is the print-out for that module
Address 55: Xenon Range Labels: 8P0-907-357.LBL
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Coding: 0000012
Shop #: WSC 06314
No fault code found.
Thanks
It should certainly be obvious if it works because,last June, I took my car to my dealer to have the headlights changed for European driving. They connected it up to their VAG5051 system and did the necessary. Whenever I switched on the ignition after that a warning message came up on the DIS to have the lights changed back when I came home.
I'm assuming I will see the same if I change them using my VAG-COM.
Hi Sebastian
I tried the headlight convert this afternoon and I think it works. Why I say I only think it works is because when I changed the setting in control module 55 channel 10 from 0 to 1 my xenons did go down slightly. Nothing came up in the information balloons about 'Tourist Option' or anything else. The screen just stayed blank when I selected channel 10.
Why I am not completely sure is that, when it was done by my dealer last year using their VAS5051 kit, a message came up on my DIS every time I switched on to remind me to change them back. No message at all when I change using VAG-COM.
