mb Posted April 9, 2008 Report Share Posted April 9, 2008 Hi installed a SE BT car-kit for a friend & all works perfectly except for a terrible noise from the microphone (can't here talking at all just crackle) I have separated the mic wire from the other wires & looped the bundled up wire around a ferrite ring but still no joy - is this OK or does wire have to pass fully once through the ferrite ring ? Stereo is aftermarket JVC & I have installed a mute wire but all other wiring (earth, live, ign live) are all separate from stereo but guess could try with stereo off/remove mute maybe ? Does anyone have any suggestions please ? Link to comment Share on other sites More sharing options...
Froggy Posted April 10, 2008 Report Share Posted April 10, 2008 What sort of interference / noise crackling are you getting over the Mic, Is it engine related or something else, and where have you mounted it? Link to comment Share on other sites More sharing options...
mb Posted April 10, 2008 Author Report Share Posted April 10, 2008 Hi, I think it is the mic as the noise is there with the engine off & the wire extended all the way out so I am standing 2m from the car ! I tried the mic on a PC and it seemed not to work but not sure if it should ? Will try the mic in my Nokia kit & see if that produces the same symptoms - do you know if all mics are interchangeable ? Link to comment Share on other sites More sharing options...
Paul Posted April 10, 2008 Report Share Posted April 10, 2008 mb, i fitted a SE BT kit to my S3 the exact same way a few years back, even the same power/mute arrangement. Eventually disasembled the mic, and fitted it in the OEM Audi position with no problems. maybe you have a duff mic? Link to comment Share on other sites More sharing options...
Froggy Posted April 11, 2008 Report Share Posted April 11, 2008 do you know if all mics are interchangeable ? They aren't normally - even some of the Nokia mics aren't fully interchangeable, (different impedances and noise cancellation properties). It does sound like a duff mic from what you have described. Link to comment Share on other sites More sharing options...
mb Posted April 14, 2008 Author Report Share Posted April 14, 2008 They aren't normally - even some of the Nokia mics aren't fully interchangeable, (different impedances and noise cancellation properties).It does sound like a duff mic from what you have described. Still haven't got to the bottom of this one... Managed to retrieve my Nokia BT box from the depths of the dash & you are quite correct the mics are different (2.5mm vs 3.5mm jack) so the hunt is on for a SE mic to try ! Link to comment Share on other sites More sharing options...
