MRI scan
DHA
don't wear anything metal and stay as still as possible.
QUOTE]
So this means you will have to remove your prince albert metalwork & nipple piercings.
The big doughnut thing can be a bit claustrophobic, and if you are a really large fella, you may not actually fit in it (body size you understand -not prince albert).
Dead straight forward but can be a bit claustrophobic. They do make a racket though. You can't feel anything other than the vibrations of the machine. You have to stay dead still and remove any metal so try not to wear jeans or a belt as taking them down and pulling them back up again while laying on the table can be a pain in the arse.
Sometimes they need to put a line into your arm to inject a chemical that will show up better but that depends on what the scan is for and what they are looking for etc.
Hope everything's ok +++
  • 2 weeks later...
Didn't have the scan that day. Was in with the neurologist for almost an hour chatting doing various tests. Am due for an MRI at some point but also some neurophysiological tests as well to see if my nervous system is working ok. I think they are a little stumped as to what it might be, the initial diagnosis had symptoms which should have subsided by now.
