Confirm activation of ATA
ludwig
Page 21 of the 3.1 Controls and equipment booklet, Opening the Convenience Menu, says:
ATA confirm - The activation of the anti-theft alarm system can be confirmed if required."
I can't see that option in my Settings/Convenience display?
Has anyone got a MY 06 with this option active?
All I've got is:
Door open
Conv. mode
Mirror adjust
Factory setting
Back
Presumably, "...the anti-theft alarm system can be confirmed.." is a 'beep' or other sound?
Thanks, ludwig
The confirmation is just a beep from the horn. You can active the beep itself and enable the menu option using VagCom and going into the long coding of the central convenience module.
I don't remember exactly where the option is in the long coding but it'll be pretty obvious when you see it.
You can set it to beep the horn and/or flash the indicators when you lock or unlock it using either the key or remote.
I have my .:R32 set to beep when I lock the car using the remote but have the ATA menu hidden (or blocked as it says in VagCom).
