Can I fit a 235/40 18 in the R32's wheels???
ClimberSP
Cos the correct tyre size is 225/40/18, so a 235 will be a tad wider and squeezed into a 8" wide alloy it will be a tad taller and so speedo will be affected..... but not by very much
Approximate calculation result in a 1.26% or 8mm overall diameter (4mm extra height). This is within the recommended 2.5% change allowed. How much this will affect the speedo I've no idea!
Hope this doesn't come across too techno-geeky!!
because the wider tyre would have a different rolling radius.
i THINK
the with 225x40 18 the 40 is an aspect ratio which is 40% of the 225 part, so the total diameter of the wheel would be x giving a rolling radius measure ment of x(mathmaticy bit)
soif you go to 235x40 then the 40% is of a different figure so the total diameter would be y and the rolling measurement y(mathmaticy bit).
THat make any sence?
well you cant really beat that deal.. I had those on my R32 before Iwent for the 19s. very good grip tyre but also very soft rubber... Mine had to be replaced within 6 months
That said I dont think my daily ritual of doughnutting outside the office car park helped matters NONO3.GIF
Yes, right. That's the problem and that's why they're going to go to the S4, not to the R32.
Our laws don't allow to make lots of changes in our cars and that's why we have no culture about hard preparations in our cars, the 2nd hand market it's zero if you have made an upgrade in your car, etc, etc... frown.gif
If you want to change something importanthere, you need lots of papers and lot of money rocketwhore.gif, that's dung.gif
