BMW (E90) oil change and sump
smithie
Hi all,
Great forum and very useful!
I've been looking at servicing my (E90) BMW , I've done various cars in the past but the BM has a slightly different set up as most of you will know!
I've looked underneath the car and found a "trapdoor" which appears to house the oil sump, mine is black with a 17mm black bolt but this points straight down, unlike other cars I've had it would mean you can't use a regular ring spanner to undo the nut, can someone let me know if this is actually the oil sump nut before I undo it?!
Also the oil filter access is very restricted and has a metal cover to prevent easy access! If anyone needs to know where to get hold of the tool oil filter cup wrench I'm happy to give a recommendation if you want to send me a message. I found it pretty damn hard to get the tool!
(sorry if this in the wrong section, new to this!)
Thanks for your help
Smithie
Welcome to Tyresmoke smithie :beer:
To be honest I have no idea, I send mine off to BMW and then take a hit to the wallet. If you do it yourself how are you resetting the service indicator? :confused:
Give the site below a click and you will be able to see the exploded view of the engine if you search for the model / engine you have got. Let us know how you get on. +++
RealOEM.com Online BMW Parts Catalog
