[Audi A3/S3] 19" TTS Wheels
Lee551247
Does anyone know if the Audi 19" TTS wheels will fit an Audi S3 (ie correct offset etc) Is anyone running 19"s on an S3 on here? Does it screw up the ride and handling because at the minute it drives and handles perfectly and i do not want to lose that by going to 19"s. Also will it need lowering if i put 19's on??
Any help would be much appreciated.
Cheers
Which TTS and which S3?
If it's Mk1 TTS and Mk1 S3, then yes, and if it's Mk2 TT and Mk2 S3 then yes, but not across the two. The earlier ones have a PCD of 100, the current ones have a PCD of 112.
No, you won't need to lower the car if you put 19" wheels on it. You'll get a much firmer ride (there's less of the tyre to absorb the bumps).
Make sure you match your rolling circumference of the new tyres to your old ones - you can check here Tire size calculator
Mook, Its a 2008 S3 and the 2008 TTS is th car i am refering to so do you think they will fit??
Regards
Lee
They will fit I believe, but the offset is slightly different meaning you're running close on the rear arches. There is a screw in the rear arch that holds the bumper sides flush with the rear 3/4 panel. You can ditch the screw and it causes no problems.
I think the TT-S runs 255 tyres, but on the s3 you'd need to go 235/35
I've just put 19"s on mine actually:
My car is lowered on H&R springs (-25mm) to finish the look.
You could just add wheel spacers (10mm at each wheel or 12mm if you don't mind removing the screw on the rear arch) :
With spacers only:
With Spacers and lowered:
Without spacers:
Hope that helps
