festinc Posted January 18, 2009 Report Share Posted January 18, 2009 I've had a problem wit my golf for nearly a year, the headlights, full beam and the inside light all dim slightly (rev counter bounces, usually between 6-8 hunderd revs but sometimes stays at 1.1k revs), power while driving goes and only kicks in after 3k revs, and stalls a fair bit in neutural. I've taken it to a garage and after hooking it up to the computer, i had 3 problems appear. 16500 P0116 Engine sporadics Coolant temperature circuit - G62t range performance 16684 P0300 Random Multiple cylinder: misfire detected 16687 P0303 Cylinder 3: misfire detected Any ideas whats happening and how to fix them? btw its on 03 plates and a 1.4 Link to comment Share on other sites More sharing options...
benjie Posted January 18, 2009 Report Share Posted January 18, 2009 Sounds like your coolant temperature sensor is buggered mate, change that first, then report on the change(if any). It might cure the other misfires/idleing problems as they seem to be caused by something else. Link to comment Share on other sites More sharing options...
