External differences between A6 and RS6
grahamb
Is the bodywork actually wider on the RS6? Or is it just an optical illusion from the phat wheels that are squeezed underneath? Does the RS6 have different front and rear wheel arches? I keep seeing RS6's and drooling like a mad'un. There must be a reason why laugh.gif
TIA
Graham
My A6 owners manual says that the width is 1810mm and the width including mirrors is 1983, so 1810mm must be wheel arch to wheel arch.
Wots the dims of the RS6 then?
BTW, what are the 5 spoke wheels that are fitted to the RS6? Are they 18" or 19"? And wots the width? I may be buying a set...
So the Arches are the same im affraid
The arches on the RS6 are the same as all other V8 A6 models. These are wider than the arches on the smaller-engined versions. Indeed, the front wings and bonnet of the V8 cars are also longer than the others (and made from aluminium instead of steel).
  • 4 weeks later...
