2.5TDI V6 warm up - takes ages -common?
waynester2
Hi Guys, I've notice my A4 ('04 2.5TDI 163 CVT V6 Saloon) is taking an age to warm up these days, just took it for a drive tonight, from cold it was 6c outside but took 20 mins to get upto 90c which is where it normally sits, anyone else's 2.5tdi take this long to warm up? This was not slow roads either it was a mixture of A and B roads, I'm concerned that the thermostat might have gone causing coolant to go around the radiator full time, does this happen with these cars? Any advice appreciated, I remember my 1.8t warming up much quicker!!!
Thanks
W
diesels have a supplemental heater thingy to warm up the car don't they?
maybe thats broken on yours. the diesel engine itself will take 15-20mins to heat up. petrol engines warm up quicker.
I timed mine today, and it was at 90 in 8 mins. I travel most of the start of my journey on a dual cariageway. This was at 70 - 75mph
When you say burst do you mean 'burst' :eek: or 'leak'?
If it 'burst' then there was a blockage somewhere and muck etc may be lodged in the thermostat wedging it slightly open all of the time.
Start the car and run it for about five minutes and then check the temperaature of the top radiator hose. It should still be cool, indicating that the thermo is still shut.
Is there not an auxiliary heater - webasto - on that engine at that age? Could be some of the sensors/wiring has been disturbed.
Did it warm up quickly before the read. incident? +++
If it is the thermostat.................................
First remove the front of the engine.........................
Not the best bit of automotive design then............................
Edited by maersk
Removing and installing additional heating heater element -Z35
Notes:
  • <LI class=nonenone>â—† Checking operation of additional heating heater element -Z35.
  • â—† Vehicles with diesel engine are currently fitted with an electric additional heater (heat energy is added to air flow immediately after exiting from heating system heat exchanger).
Audi Sales Range
  • â—† Vehicles with diesel engine and "auxiliary heater" as optional extra may not be fitted with an electric additional heater depending on vehicle control system. On such vehicles, this function is assumed by the auxiliary heater, which operates as a fuel-driven additional heater (by adding additional heat energy to the coolant).
  • <LI class=nonenone>â—† Vehicles with petrol engines are not currently equipped with an additional heater.
  • â—† Replacement air distributor housings all have an opening for an additional heating element. If the vehicle has no additional heating element, the opening is to be sealed with a cover.
Removing
  • ‒ Remove driver's storage compartment.
‒ → Unplug connectors -A- , -B- and -C- from heating element -B-.
  • ‒ → Remove bolts -A- and pull additional heating element -B- out of heater.
Installing
  • ‒ Additional heating element -B- is only to be installed in heater with rubber bushes -D- at lugs -C-.
Then re-install all components removed in reverse order.
I was over exaggerating, it started to leak and gradually got worse, I had it replaced within a week of it starting to leak.
Does my car have an aux heater? it is very strange how the heaters take ages to warm up straight after having the rad replaced, its not losing any water now.
