Mex77 Posted January 30, 2009 Report Share Posted January 30, 2009 Does anybody have the login code for changing softcode on ABS/ESD module? Link to comment Share on other sites More sharing options...
PetrolDave Posted February 3, 2009 Report Share Posted February 3, 2009 Tried 40168? Link to comment Share on other sites More sharing options...
Mex77 Posted February 3, 2009 Author Report Share Posted February 3, 2009 Yes, but that code is just for setting the steering wheel in 0 position. The only thing left to do to get the PRNDS to show up in the FIS-display has to be that controller, because i don´t get the "brake pedal warning" anymore It looks like this now: Audi S8 -01 Sport 50-150km/h - GARAGET - www.garaget.org Link to comment Share on other sites More sharing options...
Mex77 Posted February 3, 2009 Author Report Share Posted February 3, 2009 Im using 704.1. ECU 4D0 907 559 C TCU 4D0 927 156 EC (softcoded 00121) ABS 4D0 907 389 E (softcoded 08397) INST 4D0 919 033 CE Link to comment Share on other sites More sharing options...
Phil_S Posted February 3, 2009 Report Share Posted February 3, 2009 try looking here im sure it shows you how to generate the proper code for the unit dependant on parts etc Audi A3/S3 & A3 Cabriolet (8P - Ross-Tech Wiki) Link to comment Share on other sites More sharing options...
Sebastian Posted February 3, 2009 Report Share Posted February 3, 2009 What exactly are you trying to do here? Please post a complete scan from the entire vehicle, we need more details on those control modules. Make sure to use at least Release 805.2, Release 704 which you are using is outdated. Link to comment Share on other sites More sharing options...
Mex77 Posted February 3, 2009 Author Report Share Posted February 3, 2009 I think i can recode my modules just fine with the 704.1 software, but i cannot log in to the ABS/ESP control unit without the correct code. If it´s not the ABS/ESP that needs recoding then what makes the "foot on brake pedal" come up when i turn on the ignition? It should be the same thing that makes it not to show the PRNDS in the display (as you see in the film). :confused: Link to comment Share on other sites More sharing options...
PetrolDave Posted February 4, 2009 Report Share Posted February 4, 2009 I think i can recode my modules just fine with the 704.1 software But if you can run 704.1 then surely you have a genuine Ross-Tech lead, so 805.2 is a FREE download - so what's the point in not using the latest version? Link to comment Share on other sites More sharing options...
Mex77 Posted February 4, 2009 Author Report Share Posted February 4, 2009 Ooh, no that won´t work as the cable then will lock itself, doesn´t get less genuin than that... Link to comment Share on other sites More sharing options...
PetrolDave Posted February 6, 2009 Report Share Posted February 6, 2009 Ooh, no that won´t work as the cable then will lock itself, doesn´t get less genuin than that... If you buy a "rip off" product then you get what you expect... Link to comment Share on other sites More sharing options...
Mex77 Posted February 6, 2009 Author Report Share Posted February 6, 2009 It works just fine....! I went to the dealer to get the failing gearstick fixed (you can move the stick without the key or take key out while stick is in N instead of P ) and when they had finished whatever they were doing the car wouldn´t start The instrument cluster is black and the immobiliser makes it unstartable So i´ll guess im gonna have to pay for whatever they have destroyd.... Link to comment Share on other sites More sharing options...
