Sunroof Wont Close!!
Medway
There's definitely no obstruction, I've checked and checked again. I can't hear any crunching or grinding either, it's like it's forgotten how to close itself! Do you have any idea how I get to the manual override as there's nothing in the manual?
Thanks a lot,
I drive an Audi, but at the top (on the ceiling) there is a catch to remove the plastic cover which also holds the button. When that's removed you should see the mechanism and there will be a slot of your screwdriver.. turn left or right to open/close
Thanks for that Dave, I've managed to shut it.
For the record, I had to unclip the middle part of the panel in the headlining and underneath was a silver allen bolt. All I had to do was put my allen key in, twist it with a bit of grunt in the right direction to move the sunroof back into position.
