Electrical Problems
beansy78
Hi All,
I have an 02 Passat which is suffering from intermittent electrical problems.
At times the windows will not work, remote central locking will not work and alarm seems to go off randomly. Alarm will continue to go off even when the car is started.
Also the button for opening the fuel cap or the boot doesnt seem to work anymore.
I got a friend to put the laptop on the car and he mailed me the reading below:
I dont really know anything about electrics, does anybody know what might be wrong?
VCDS Version: Release 805.3
Data version: 20090213
Tuesday,24,February,2009,14:03:22:25238
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ2E271984 Mileage: 190630km/118451miles
Address 01: Engine Labels: 038-906-019-AVB.lbl
Part No: 038 906 019 GN
Component: 1,9l R4 EDC 0000SG 1497
Coding: 00005
Shop #: WSC 05314
WVWZZZ3BZ2E271984 VWZ7Z0A4400077
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
Part No: 8E0 614 111 AB
Component: ABS 5.3 FRONT D10
Shop #: BB 24548
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B2 907 044 J
Component: CLIMATRONIC B5GP 0004
Coding: 17000
Shop #: WSC 05311
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 B
Component: 0A AIRBAG VW51 04 0004
Coding: 12353
Shop #: WSC 05311
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 927 A
Component: KOMBI+WEGFAHRSP VDO V06
Coding: 05415
Shop #: WSC 00000
2 Faults Found:
01336 - Data Bus for Comfort System
49-10 - No Communications - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00004
Shop #: WSC 05314
2 Faults Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 6T Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
Part No: 1C2959802
Component: 6T Tõrsteuer.FS KLO 0002
Part No: 1C2959801
Component: 6T Tõrsteuer.BF KLO 0002
Part No: 1C0959811
Component: 6T Tõrsteuer.HL KLO 0002
Part No: 1C0959812
Component: 6T Tõrsteuer.HR KLO 0002
5 Faults Found:
53-10 - Supply Voltage Too Low - Intermittent
00950 - Central Locking Motor - tailgate (V53); UNLOCK
25-10 - Unknown Switch Condition - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
00953 - Interior Light Time limit
25-00 - Unknown Switch Condition
01135 - Interior Monitoring Sensors
36-00 - Open Circuit
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 D
Component: RADIO SON 0004
Coding: 04401
Shop #: WSC 05311
End ---------------------------------------------------------------------
Passat Scan.txt
Hi, I support the reply from Shark......'wet carpets' have been noted on manyof the replies on the Passat site, including me. The wet carpet syndrome usually shows up on the n/s rear passenger carpet and can find a way to the front passenger areas.....water leaks from front bonnet area runs back to lowest part of car...water possibly leaking from pollen filter housing SEAL and the plenium area under battery and brake servo being a result of BLOCKED DRAIN HOLES (there are two drain holes) ??? ...(please refer to the other passat postings on water leaks as this is covered in more detail). This is assuming, of course, that there is a water leak affecting the CCM and it has entered the CCM/ECU under n/s front passenger carpet. Note...so many electrical probs is a clue to the CCM/ECU but of course, it could be something else.
If it is due to water leak and you get round to changing the filter pollen SEAL under boot, make sure you get the correct seal. VW service dept ordered my part replacement, giving me the standard foam seal which they call a gasket...you will likely need the other type they dont' offer, which is basically a kind of mastic seal of about one metre plus long, rolled up for packing...you simply cut the length needed and place under filter housing to give a water tight seal between housing and car body. The VW technicians use this to stop the leak...!!! One prob, the service centre usually sell the whole metre plus....being approx £25 and will not cut to user requirements (perhaps I was unlucky) !!! I noted on one of the other posts, they obtained this item for free?? remember, the cost of replacing the CCM will be hundreds, so be cautious on this...Of course, it should be FREE because there is a design problem....in my opinion (sorry VW but this should have been sorted quickly on the earlier models...no excuses really no excuses). If you do need a new seal why not contact me and we can work out a price for the correct length...Im just about to repair my filter sealing too, using this most expensive part. It makes sense surely to repair asap. Good luck in finding the source of the problem first; hope this assists you.
Edited by rmv
hi
check out this link
http://www.tyresmoke.net/forum/vw-passat/111247-help-passat-fills-up-water.html
or
UKpassats.co.uk • View topic - Plenum drains blocked - a helpfull guide.
i had some big problems with water getting into the car, did some research and found 2 websites to help you get through it. it is a diy job but takes time and patience.
VW Passat Comfort Control Module harness repair | HeadFUZZ
:: .:: WeirdLittleBiscuit dot Com ::. .:: Fixing Passat Leak ::. ::
i have followed these and it sorted my car, but the electronic boot realese still doesnt work ???!!!??, the worst bit is drying the car out. i was luck and already had a dehumidifier which i ran inside the car for about 4 days, and i still put it in there now and then.
please let us know how you get on
chris
