mb Posted April 28, 2009 Report Share Posted April 28, 2009 Hello Can anyone suggest where to start looking for the following problem ? I am using a genuine fully licenced copy of VCDS 805.3 but can only access some modules. The cable & software I am sure are fine as the modules are either accessed straight away or a great deal of trouble/don't work so I suspect there is a damaged wire somewhere - the car runs OK & nothing seems wrong. It is a Mk IV Golf R32 it used to have a double DIN Delta stereo in it which I replaced with an MFD Vagcom has worked fine for ages but went flakey a while back & now this which hopefully is easier to troubleshoot at least ! The K Line from the stereo is not connected hence the no comms errrors. When I try to open all the common Modules this is the result - Engine - VCDS goes in but no fault codes - too many comms errors to continue Cent Elect - No Response From Controller (NRFC) Aux Heat - NRFC Cent Locks - NRFC Xenon Range - NRFC Auto - na Air Bags - OK CAN Gateway - 1 Fault Found: 01304 - Radio 49-00 - No Communications Navi - NRFC Radio - NRFC ABS Barkes - in but no fault codes - too many comms errors to continue S Wheel - NRFC AWD - OK Inter Monitor - NRFC Auto-HVAC - OK Instruments - 1 Fault Found: 01304 - Radio 49-00 - No Communications Immo - go to 17 (Instruments) in German C Conv - NRFC I know some wouldn't work anyway but I got into the engine last week but now no joy so if anyone can suggest where to start looking it would be much appreciated Link to comment Share on other sites More sharing options...
Sebastian Posted May 4, 2009 Report Share Posted May 4, 2009 For reference: Vagcom can only access 1/2 my control modules - TDIClub Forums Link to comment Share on other sites More sharing options...
