teknition69 Posted May 4, 2009 Report Share Posted May 4, 2009 :ffs:I owned a passat 1996 TDi with the mentioned ecu it was chipped with a superchip it was the dugs . I sent it to heaven but kept the ecu no keys nowt else. I the aquired a Golf mk3 1997 TDi same ecu no but with the letters ending BF I fitted the ecu and it ran for about 2 secs. Yup I now know its something to do with keys I do not have the old keys.I have vag Com can I do any thing with it or do I have to go to VW no no no . Hope someone out there can help Regards Link to comment Share on other sites More sharing options...
Phil_S Posted May 4, 2009 Report Share Posted May 4, 2009 someone may correct me on this but if i recall vagcom can only duplicate keys, not remove the required value from the ecu and program a key, you should find a little tool for doing that on ebay i think Link to comment Share on other sites More sharing options...
shark_90 Posted May 5, 2009 Report Share Posted May 5, 2009 Try this: Install the new ECU in the car[select][17 - Instruments][Adaptation - 10]Leave channel at "00"[Read][save] [Done, Go Back][Close Controller, Go Back - 06][Exit] Turn ignition OFF for 15 seconds. Start vehicle. If it doesn't work then try module 25 Immobiliser instead. Link to comment Share on other sites More sharing options...
