Greasymech Posted May 27, 2009 Report Share Posted May 27, 2009 Make: Volkswagen Model: Passat 4 dr saloon Year: 2006 my Engine: 2.0 tdi 140 ps man Engine Code: Mileage: 21000 ! Afternoon all, Fault................Steering lock information on dashboard saying " steering column lock ! visit workshop " Remedy........... Visit VW dealer, give them £82 pounds to plug into system only to be told, it could be either?, the ignition switch £200 or the steering column, complete at £2500 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Had this car from new and no problems until now, wife drives it. I am a skilled vehicle mech, but a bit points and condensor when it comes to these new keyfob insert thinggies. Help would be appreciated folks. Link to comment Share on other sites More sharing options...
ACFraser1 Posted May 29, 2009 Report Share Posted May 29, 2009 I've had similar problems. I have a VW 2litre 140 bhp 2006 new passat. I had the diagnosis done twice, once by VW and once by an independent garage. Diagnosis was faulty steering column lock, but to fix this it required a new steering column and a new convenience control unit. Cost £745 inc vat. The garage managed to get a goodwill discount of 25% from VW. Hope this helps Andrew Link to comment Share on other sites More sharing options...
Greasymech Posted May 29, 2009 Author Report Share Posted May 29, 2009 Will try and go down the same route and claw back some money from wolfsburg. Worked on loads of motors in my years but never come across a steering lock problem in such a low mileage car, not to old a vehicle. Thanks again. Link to comment Share on other sites More sharing options...
ACFraser1 Posted May 29, 2009 Report Share Posted May 29, 2009 I'm also going to try to get more money back from VW. To me a steering lock issue must either be a design defect or a manufacturing defect. Surely can't be anything to do with how the car is driven (even though I drive it with care) Link to comment Share on other sites More sharing options...
Greasymech Posted July 22, 2009 Author Report Share Posted July 22, 2009 Remedy to this problem was to replace battery ! Have had no problems since this. Drop in battery charge must trigger this fault. £60 battery was much cheaper than a new steering column. 1 Link to comment Share on other sites More sharing options...
Greasymech Posted October 8, 2009 Author Report Share Posted October 8, 2009 Update on steering lock. All ok october 2009. Link to comment Share on other sites More sharing options...
StephenGoodRepair Posted October 21, 2009 Report Share Posted October 21, 2009 Hi guys, you are lucky to have a cheap solution. Did your dealers not read the failure codes out of the diagnostics ? Normally they can print a book of 30 pages and should find the reason of the bug in this booklet. You should always ask them to give you a copy - it's your money and you pay them a lot for each minute they spend ... Link to comment Share on other sites More sharing options...
Greasymech Posted November 15, 2009 Author Report Share Posted November 15, 2009 update on steering lock. All ok Nov 09. Link to comment Share on other sites More sharing options...
Karman Posted July 21, 2010 Report Share Posted July 21, 2010 To Greasymech- did you have any known problem with your battery originally? I have been having the same steering column fault error with my Passat 05 1.9 SE TDi and the VW dealer garage did not mention anything about the battery, all they suggest is a replacement of the steering column at a huge cost (£900!); bettey voltage checked out fine. Link to comment Share on other sites More sharing options...
snutz Posted September 30, 2010 Report Share Posted September 30, 2010 I just registered to say the same thing happened to our 2006 Passat. The intermittent no start thing started happening so we tried all the temporary fixes (waiting for the light to change color, moving the wheel, etc.) until the whole thing died. We took it to our local dealer here in Salt Lake, described the problem, told them we knew that this was a well documented issue, and that we had already talked with VWofA. They kindly fixed the problem even though the car was just out of warranty. I wanted to let people know that it looks like in at least some cases VW is making this right. Good luck to everyone that still has this problem. Link to comment Share on other sites More sharing options...
aimermoi Posted October 11, 2010 Report Share Posted October 11, 2010 My 06 passat has the same problem. Diagnosis from the dealer required three repair: 1. Steering Column 2. Convenience/Comfort Control Module 3. Battery. Since I read about this problem with many Passat owners, I contact VWofA and explain to them the issue. They agree to pay for the repair of the Steering Column but not the Convenience Control Module. I hope the changing the battery will take care of the issue. I will try soon. Thanks Link to comment Share on other sites More sharing options...
Conan Pollock Posted January 15, 2014 Report Share Posted January 15, 2014 Hey, my car has been doing this fr almost 8 months, but as its up for MOT now at the end of the month! is there any quick and cheap fixes out there before i think about buying the steering column? Link to comment Share on other sites More sharing options...
