les Posted May 31, 2009 Report Share Posted May 31, 2009 hi can anyone help please,our golf 1.6cc 2001 model (azd engine code),well its a problem starter;starts first time of the day later or when warm engine will crank over maybe start then stutter 500 revs then 600 revs then 700 revs etc. engine takes time to pick up the full 1000 revs it needs once started great,rarely when ive gone to work the engine loses power for a split second and comes back to life with a jolt as i say for a split second on a rare occasion this has happened,i have serviced car oil filter air filter and such, please please can anyone help me ive run out of ideas and dont want to change every sensor until i find out the costly way please can anyone help les Link to comment Share on other sites More sharing options...
shark_90 Posted May 31, 2009 Report Share Posted May 31, 2009 Hi Les Have you changed the coolant temperature sensor? Welcome to the forum Link to comment Share on other sites More sharing options...
faultswagons Posted June 21, 2009 Report Share Posted June 21, 2009 hi, I was looking for someone on this site who might know a thing or 2 about my engine problem. so i thought i would ask your good self i have a mk 3 tdi golf, and yesteday i put a new radio in it, and it blew its fuse, so i changed the fuse then the blinkng car wouldnt start. so i checked all the fuses and none of them had blown..... so i then checked to see if i was getting the coil light coming on when i turn the key ( 109 relay) and yep the coil light comes on for a sec then goes off. ok .,.then i turn the key to start the car... it will start if i hold the key hard over to engage the starter motor, engine fires up, but with as soon as i let the key go it cuts the engine off. so i then thought ok i screwed up the immobiliser??? so i found it under the dashboard and un hooked the cables connected into it, to see if it would make the engine start or not.. well engine turns over but wont fire up,,, so ok put the wires back on the immobiliser. then tried to start it again, same as the first time, engine will fire up if i hold the key hard over, :confused: so im lost. Not sure what happend when i plugged in a new radio, as the car worked great before that. are there any hidden fuses under the bonnett? ive checked ever fuse in the fuse box area and all the relays but still cant get it to start. please can you help with your fountain of knowledge to see if you have any tricks i can try??:D many thanks j Link to comment Share on other sites More sharing options...
shark_90 Posted June 21, 2009 Report Share Posted June 21, 2009 I'll reply in your other thread Link to comment Share on other sites More sharing options...
