xpeterpx Posted July 17, 2009 Report Share Posted July 17, 2009 Still getting to grips with vagcom personally but also have my eye on an RCD 300 double din head unit. Unfortunelty it doesnt have a code... I have the full registered version of vagcom - will this help me code the stereo? Cheers Pete Link to comment Share on other sites More sharing options...
shark_90 Posted July 18, 2009 Report Share Posted July 18, 2009 No, unfortunately not. The code that you need can't be seen by VCDS. Link to comment Share on other sites More sharing options...
xpeterpx Posted July 18, 2009 Author Report Share Posted July 18, 2009 No, unfortunately not. The code that you need can't be seen by VCDS. Ah,thanks. A bit more investigation suggestes the double din unit wont fit anyway as its a different shape,plus the unit is CAN based and my Bora is NON CAN based...whatever that means Any ideas on double din units available that are suitable? Thanks for the ongoing help Link to comment Share on other sites More sharing options...
PetrolDave Posted July 18, 2009 Report Share Posted July 18, 2009 A bit more investigation suggestes the double din unit wont fit anyway as its a different shape... The double DIN units are a different shape and size to single DIN units - to fit a double DIN unit you will have to convert your dash to a double DIN one. Many people do it so that they can fit an OE sat nav unit. Link to comment Share on other sites More sharing options...
