naexcell Posted September 5, 2009 Report Share Posted September 5, 2009 Hi, When I lock the doors of my 2000 Audi A3 1.9 TDI either with the key or key thob, after about 20 seconds the hazard warning lights start flashing continuously. Only stops when I re-open the car. Any guidance would be much appreciated. Kind regards. Nic Link to comment Share on other sites More sharing options...
sam87 Posted October 13, 2009 Report Share Posted October 13, 2009 Hi, I have the exact same problem in my 2006 holden barina. Its really annoying and embarrassing. Did you get yours fixed? Any help would really be appreciated... I'm worried its gonna cost a lot to get fixed... Link to comment Share on other sites More sharing options...
NHN Posted October 22, 2009 Report Share Posted October 22, 2009 Sounds like the alarm is setting of & you havnt got the alarm chirps coded on, just teh blinkers, so possibly 2 things here need sorting, check with vagcom for both tbh mate. Link to comment Share on other sites More sharing options...
PetrolDave Posted October 23, 2009 Report Share Posted October 23, 2009 Hi,When I lock the doors of my 2000 Audi A3 1.9 TDI either with the key or key thob, after about 20 seconds the hazard warning lights start flashing continuously. Only stops when I re-open the car. That suggests that the alarm isn't setting because it thinks that one of the doors (or tailgate) is open, or the interior monitoring system thinks there's something moving inside the car. Look with VAG-COM to see if the central convenience module is storing any fault codes, as it sounds to me like you either have a problem with one of the door switches, or with the interior monitoring system. Link to comment Share on other sites More sharing options...
