Gareth Posted October 16, 2009 Report Share Posted October 16, 2009 Assume the local VW dealership is the place to get these if you don't want to use the AUX input only?? How much are they, and is there an aftermarket version as an alternative? Thanks. Link to comment Share on other sites More sharing options...
shark_90 Posted October 16, 2009 Report Share Posted October 16, 2009 The VW unit is called the MDI, not sure how much it costs. The best aftermarket device is the Dension Gateway 100/300. The 100 is iPod and Aux, the 300 is IPod, USB and Aux. The price difference is £50 between the two gateways. The major advantage of the Dension over the MDI is that you can have the iPod and USB connected at the same time and switch between then, whereas with the MDI you'd have to fiddle around swapping cables in the armrest/glovebox. Not good while driving! I'm a Dension dealer now so if you need any more info or pricing just give me a shout. Link to comment Share on other sites More sharing options...
burble Posted October 16, 2009 Report Share Posted October 16, 2009 If the Scirocco has the MDI installed (I don't know if it's a standard fit) then you just need a cable from your VW dealer. The part number is 000 051 446 C and they cost about £25. Link to comment Share on other sites More sharing options...
Atlantis Posted October 16, 2009 Report Share Posted October 16, 2009 The iPod and USB leads for the MDI should be supplied with the car. They don't come from the factory but the dealer is meant to add them during PDI. You shouldn't have to pay for them. Link to comment Share on other sites More sharing options...
Gareth Posted October 19, 2009 Author Report Share Posted October 19, 2009 The iPod and USB leads for the MDI should be supplied with the car. They don't come from the factory but the dealer is meant to add them during PDI. You shouldn't have to pay for them. As supplied the car has a USB cable under the front centre arm rest but that doesn't fit the ipod (Nano in this case) Therefore I assumed another cable-that you have to buy as with most makes-is required to use the ipod whilst also charging it. Otherwise the AUX input can be used but that won't charge the ipod of course. Link to comment Share on other sites More sharing options...
Gareth Posted October 19, 2009 Author Report Share Posted October 19, 2009 If the Scirocco has the MDI installed (I don't know if it's a standard fit) then you just need a cable from your VW dealer. The part number is 000 051 446 C and they cost about £25. Yes the MDI is standard in the 2.0GT Fsi Scirocco - and thanks for posting that code for the cable. Sounds like that is what is needed here... Link to comment Share on other sites More sharing options...
Atlantis Posted October 19, 2009 Report Share Posted October 19, 2009 As supplied the car has a USB cable under the front centre arm rest but that doesn't fit the ipod (Nano in this case)Therefore I assumed another cable-that you have to buy as with most makes-is required to use the ipod whilst also charging it. Otherwise the AUX input can be used but that won't charge the ipod of course. Yes it is a different cable, but it should be included by the dealer too. You should get both cables as standard (I know it's only £25 for one, but it's the principle!) Link to comment Share on other sites More sharing options...
Gareth Posted October 20, 2009 Author Report Share Posted October 20, 2009 Yes it is a different cable, but it should be included by the dealer too. You should get both cables as standard (I know it's only £25 for one, but it's the principle!) Thanks. Are you 100% sure it is standard?? Most manufacturers do not include the ipod lead with any car and you have to buy it at the time of purchase.....would be surprised if it was standard but happy to be proven wrong! Link to comment Share on other sites More sharing options...
Gareth Posted October 20, 2009 Author Report Share Posted October 20, 2009 Yes it is a different cable, but it should be included by the dealer too. You should get both cables as standard (I know it's only £25 for one, but it's the principle!) Just spoke to VW customer services and they confirmed the lead isn't standard and you have to buy it. Perhaps you got yours thrown in FOC as a goodwill gesture because you bought your car new? So another lead for £25 it is then!! Link to comment Share on other sites More sharing options...
Gareth Posted October 20, 2009 Author Report Share Posted October 20, 2009 Mystery over and £25 saved!! The lead supplied with my car is the wrong one (can be used for laptops I think) and the correct one is part number; 000 051 446C - as posted earlier So the VW dealer is sending me the correct one FOC. Lovely jubbly! Link to comment Share on other sites More sharing options...
burble Posted October 20, 2009 Report Share Posted October 20, 2009 The USB lead isn't for laptops, it's if you want to plug a USB flash drive or USB hard drive into the MDI. Link to comment Share on other sites More sharing options...
Atlantis Posted October 20, 2009 Report Share Posted October 20, 2009 (edited) Just spoke to VW customer services and they confirmed the lead isn't standard and you have to buy it. Perhaps you got yours thrown in FOC as a goodwill gesture because you bought your car new?So another lead for £25 it is then!! VW customer services don't know their arse from their elbow. Check out the price list Page 5 - http://cdn.volkswagen.co.uk/assets/common/pdf/pricelists/scirocco-pricelist.pdf – MDI (Multi Device Interface) with USB and iPod connection cables It's a bit strange that the leads don't come with the car from the factory, and the dealer has to add them at PDI, but that's how it is. Check out IPod Connection - Roccopedia Edited October 20, 2009 by Atlantis Link to comment Share on other sites More sharing options...
Gareth Posted October 21, 2009 Author Report Share Posted October 21, 2009 The USB lead isn't for laptops, it's if you want to plug a USB flash drive or USB hard drive into the MDI. Righto, cheers. Link to comment Share on other sites More sharing options...
Gareth Posted October 21, 2009 Author Report Share Posted October 21, 2009 VW customer services don't know their arse from their elbow. Check out the price list Page 5 - http://cdn.volkswagen.co.uk/assets/common/pdf/pricelists/scirocco-pricelist.pdf– MDI (Multi Device Interface) with USB and iPod connection cables It's a bit strange that the leads don't come with the car from the factory, and the dealer has to add them at PDI, but that's how it is. Check out IPod Connection - Roccopedia Agreed, waste of space at VW CS!! My car was supplied with the wrong lead and it has (I hear) happended to quite a few cars since launch. Link to comment Share on other sites More sharing options...
MRKJM Posted November 14, 2009 Report Share Posted November 14, 2009 Both cables are supposed to be supplied free of charge from your dealer on collection of the car. This topic has been mentioned many times on the Scirocco Net & Scirocco Central forums. So your dealer aint doing you any favours by giving them to you as if you buy a new car they are your's to start with. Link to comment Share on other sites More sharing options...
