tink Posted December 6, 2009 Report Share Posted December 6, 2009 My '07 Cooper S (Turbo) has a rattle / knocking sound from the clutch or gearbox (not 100% sure which) when the car is sat in neutral ticking over. When you depress the clutch the rattle / knocking sound stops. When you disengage the clutch and return to neutral the rattle / knocking starts again. The car has been back to BMW and they say that this is normal that the Mini Cooper S are supposed to make this sound (louder then a diesel). Can anyone help or has anyone had the same problem. Link to comment Share on other sites More sharing options...
Tipex Posted December 7, 2009 Report Share Posted December 7, 2009 Not sure if it has DMF (Dual Mass Flywheel) or not, but if so, that is your most likely culprit. Link to comment Share on other sites More sharing options...
