cuban11182 Posted December 10, 2009 Report Share Posted December 10, 2009 Here is what happens. I clear the codes and when I push the button on the shifter all the gear display lights light up. When I look it up it says look at the steering wheel controls (which the jetta has none) and under steering it says 00194 Ignition Key Removal Lock: Implausible Signal. What is that telling me? Did I need to do anything else? Any advice would be greatly appreciated. I tested the MVB and saw that when I shifted into gear that it showed correctly on VagCom. It is still throwing an error that lights up all the Gear Indicator lights. When I first start my car in the morning everything looks normal. It throws the code whenever I touch the button on the gear selector to switch it into gear. I'm actually starting to think it is the gear selector lever (althought I see the gear display tell me the right gear in Vag). I was just reading through the Bentley Manual and it gives me a way of testing the Selector Mechanism. One this to test is with the Brake Pedal depressed: Solenoid for selector lever lock releases selecter lever. It is possible to shift into a driving gear. Slowly shift selector lever from "P" through to "S", checking whether selector lever position in instrument cluster corresponds to selector lever position Link to comment Share on other sites More sharing options...
