eldiablorubino Posted January 3, 2010 Report Share Posted January 3, 2010 (edited) Had a good run to Torquay and back for the FA Cup yesterday but noticed a possible problem. When the engine was under load (climbing hills or pulling away from roundabouts) with 4 people on board I noticed the engine revs dipping and surging by a couple of hundred RPM. This was mainly from 50mph up to motorway speeds and when climbing hills with a steady throttle. Pressing the throttle harder causing the gearbox to change down stopped the problem. It felt like the clutch was engaging and disengaging slightly, hence riding the clutch slightly and causing the revs to rise. The dips and surges only lasted a second or so but were noticable to all on board and we all agreed it felt like the clutch. It was best described as a hesitancy as if the DSG was thinking of changing down and then not. Also when pulling away harder from slow speeds there was a slight judder or shake noticable midway through each gear. Today when driving with just me on board I have noticed the revs are still dipping and surging slightly when climbing hills but it is much less noticable. Any ideas? Anyone else had a similar issue? I have just reached 36600 miles and the car has been serviced annually (last time was september). Edited January 3, 2010 by eldiablorubino typo Link to comment Share on other sites More sharing options...
RedRobin Posted January 3, 2010 Report Share Posted January 3, 2010 (edited) .... Have you had a specific DSG service - DSG oil and filter change - yet? I had what I thought was a similar problem a couple of times but think it was the rev limiter - Now sorted by upping the limit. Edited January 3, 2010 by RedRobin Link to comment Share on other sites More sharing options...
shark_90 Posted January 3, 2010 Report Share Posted January 3, 2010 I think you'd know if it was the rev limiter, because it would be screaming it's proverbials off! Link to comment Share on other sites More sharing options...
eldiablorubino Posted January 3, 2010 Author Report Share Posted January 3, 2010 No I haven't had/asked for/been recommended a specific DSG service. The issue was most noticable around 3000 rpm when the engine was under steady/constant load climbing hills on the A303 and M3. So not a rev limiter issue. As I said the closest thing I can describe it to was as if letting the clutch in to go for a gear change but then releasing it again. But not completely letting the clutch in, just enough to raise the engine revs by about 150-200 rpm. Link to comment Share on other sites More sharing options...
carnell Posted January 6, 2010 Report Share Posted January 6, 2010 No I haven't had/asked for/been recommended a specific DSG service.The issue was most noticable around 3000 rpm when the engine was under steady/constant load climbing hills on the A303 and M3. So not a rev limiter issue. As I said the closest thing I can describe it to was as if letting the clutch in to go for a gear change but then releasing it again. But not completely letting the clutch in, just enough to raise the engine revs by about 150-200 rpm. Been a few owners with the mechatronics module problems, which i think controls the dsg box, but i dont know what symtoms you get with that ? Link to comment Share on other sites More sharing options...
RedRobin Posted January 6, 2010 Report Share Posted January 6, 2010 .... Typical Mechatronics problem is unable to select a gear or gears and/or the display going bananas. Obvious evidence of problems. Link to comment Share on other sites More sharing options...
jhal Posted January 8, 2010 Report Share Posted January 8, 2010 had a similar issue myself, around the same mileage too. took it back to the dealer twice, they kept it over night too. they never found a fault, even though one mechanic, could feel it. the computer says no, so there was no problem... it seemed to be worse when the gearbox was hot, after say 20 mins. it felt like the clutch was juddering, like a manual dry clutch had a little oil on it. it just went away one day, never been back. 66Kmiles now might be no harm in changing the oil though. Link to comment Share on other sites More sharing options...
eldiablorubino Posted January 11, 2010 Author Report Share Posted January 11, 2010 Still happening it seems, but most noticeable when 2 or more on board. Will wait and see for a bit. If it continues/gets worse after the thaw has occured I'll take it to the dealers... Out of warranty now though of course!! Link to comment Share on other sites More sharing options...
jhal Posted January 12, 2010 Report Share Posted January 12, 2010 let me know what they say, i would be interested to know if their computer finds anything. thanks Link to comment Share on other sites More sharing options...
ludwig Posted February 1, 2010 Report Share Posted February 1, 2010 Eldiablorubino, just making sure you've seen this sent to me and others in the last few days: "Sent From: knobbie Subject: dsg __________________________________ I see you have some pretty strong views on the DSG problems people are experiencing and the VW/Audi UK not extending the warranty like they have in the US. Well a group of us felt the same and have setup a website to register peoples faults, armed with this we are going to approach VAG about extending the warranty after we have a good number of people signed up. The site is DSGwoes.co.uk - Index, any support you can offer would be greatly appreicated. We need to increase the traffic to the site and in turn get more members signed up. Any questions give me a shout. Cheers Dave [email protected] " I've registered. Very interesting letters (2) from VW America Hope it helps, Ludwig Link to comment Share on other sites More sharing options...
Andyuk911 Posted February 2, 2010 Report Share Posted February 2, 2010 Does the DSG box work ok in the latest Mk6 Golf GTI ? Thanks Link to comment Share on other sites More sharing options...
RedRobin Posted February 4, 2010 Report Share Posted February 4, 2010 Does the DSG box work ok in the latest Mk6 Golf GTI ?Thanks ....They all work per se, including the Mk5 DSG boxes. It's just that, like anything mechanical, faults can develop and people assume the worst about the cost of DSG repairs. 80k miles on mine and Revo2 and nothing serious so far. Mk6? - Far too soon to say methinks. Link to comment Share on other sites More sharing options...
eldiablorubino Posted February 26, 2010 Author Report Share Posted February 26, 2010 Hi Guys, sorry i've not been around for a few weeks... long story. Have not had my car looked at yet, but have been in contact with the dealer and should be leaving the car with them for a day in the next week or so. Thanks Ludwig for the link, very interesting! Matt Link to comment Share on other sites More sharing options...
eldiablorubino Posted March 4, 2010 Author Report Share Posted March 4, 2010 My GTI has been in the dealers all day having the issue looked at... Have just picked the car up and they have said it needs a complete new DSG gearbox (NOT just the mechatronics unit). I have to wait until Monday to hear what VW UK will do as the car is 6 months out of warranty. Asked what a ballpark figure for new DSG is, she said ROUGHLY £3500... Matt Link to comment Share on other sites More sharing options...
JonC Posted March 4, 2010 Report Share Posted March 4, 2010 Ouch! Bet you wished you'd purchased some extended warranty now. Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted March 5, 2010 Report Share Posted March 5, 2010 That's one hell of a cost! That's now a large percentage of the car's value. I suspect you could buy a new engine for some cars cheaper than that. I'd be thinking about trading it in for that sort of a cost and getting shot of it. Perhaps a letter to VW might help. Even if they would contribute 25% that would help. Got to be worth a try. Link to comment Share on other sites More sharing options...
stooH Posted March 8, 2010 Report Share Posted March 8, 2010 Ouch. That's not good at all, pretty disapointing that a major component like that would fail after 3 1/2 years, my GTI's at 60k miles and a couple of months out of warranty, really don't fancy that going or it would blow my plans out of the water to buy a new car in a year or so. Link to comment Share on other sites More sharing options...
Tipex Posted March 8, 2010 Report Share Posted March 8, 2010 There will always be the odd one or two failures, which with a 'normal' gearbox, you can just about swallow if the worst happens, but owning a DSG equipped car outside the warranty period is a massive gamble, I fully expect the price of DSG cars to massively nosedive as they get older, and people realise the potential cost of failures. Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted March 8, 2010 Report Share Posted March 8, 2010 I'm not sure that DSG failures are common enough to hit residual values. It was a consideration when I bought my GTI though as she's a keeper. Link to comment Share on other sites More sharing options...
RedRobin Posted March 9, 2010 Report Share Posted March 9, 2010 There will always be the odd one or two failures, which with a 'normal' gearbox, you can just about swallow if the worst happens, but owning a DSG equipped car outside the warranty period is a massive gamble, I fully expect the price of DSG cars to massively nosedive as they get older, and people realise the potential cost of failures. ....Instances of DSG failures are no more than manual clutch failures. The 'gamble' with a DSG car is no greater than with any other component on a car and it's certainly not "a massive gamble". As always, the key to it is regular and good maintenance. Coming up to 5 years old and just over 80,000 miles. Link to comment Share on other sites More sharing options...
Tipex Posted March 9, 2010 Report Share Posted March 9, 2010 It is a massive gamble when I could get a clutch done for a few hundred quid, or a DSG gearbox for 3.5k. And if DSG gearbox failiures are 'as common' as manual clutch failures then I'd be hugely worried if I owned a DSG car out of warranty, as almost every manual car will require at least one clutch change in it's life. Link to comment Share on other sites More sharing options...
JonC Posted March 9, 2010 Report Share Posted March 9, 2010 DSG "problems" are minimal compared to that of a manual car with a clutch. Link to comment Share on other sites More sharing options...
bazza_g Posted March 9, 2010 Report Share Posted March 9, 2010 really hope VW help you out especially as it's not far out of warranty and hasn't done mega miles. On the brightside at least its not a GTR box....! Link to comment Share on other sites More sharing options...
Tipex Posted March 9, 2010 Report Share Posted March 9, 2010 DSG "problems" are minimal compared to that of a manual car with a clutch. I dare say your right, I think RR inadvertently made the problems sound worse/more prevalent than he intended. But, personally, I'd rather have the bill for a manual gearbox than a DSG, thats what I'm saying, and I do believe it'll make DSG cars unpopular on the second hand market. Say for example, you buy a 10 year old GTi DSG, for say, £2k (looking at the average price of currently 10 year old GTi's), and the gearbox pops, the bill for a new box is going to make the car totally uneconomical to repair, there aren't that many components in the car that can ever cost that much, you could get a re-con manual for £500 fitted, even a replacement engine would only set you back a grand. At some point, they'll become white elephants that no-one will touch. Link to comment Share on other sites More sharing options...
Cuprabob Posted March 9, 2010 Report Share Posted March 9, 2010 An ABS control unit would set you back £1.5k which could equally fail on a 10yr old car. The thing about DSG and the complexity is that very few people can repair them and as such go down the route of a full gearbox replacement vs replacing the faulty component. Link to comment Share on other sites More sharing options...
