vwpassest Posted February 5, 2010 Report Share Posted February 5, 2010 got problems with water coming in drivers side foot well area, where do you start looking. drivers door has had screwdriver forced in halfway up window but no signs of rain ect coming in there.:confused: Link to comment Share on other sites More sharing options...
Mook Posted February 5, 2010 Report Share Posted February 5, 2010 Welcome to Tyresmoke It's a common problem on Passats. The drain hole in the scuttle panel (under the bonnet in front of the windscreen) gets blocked. Water builds up and ends up in the footwell. To fix the problem, remove the pollen filter and you should be able to see the drain hole. unblocking from underneath is normally what's needed. HTH Link to comment Share on other sites More sharing options...
EddyH Posted February 5, 2010 Report Share Posted February 5, 2010 On the drivers side it can also be the grommit around the bonnet release cable but I'd check the plenum drains and the pollen filter housing seal first as advised by Mook. Link to comment Share on other sites More sharing options...
vwpassest Posted February 5, 2010 Author Report Share Posted February 5, 2010 :D thanks for the tips lads, will try that first chance i get will keep you informed:ffs: Link to comment Share on other sites More sharing options...
Mook Posted February 5, 2010 Report Share Posted February 5, 2010 You're welcome Link to comment Share on other sites More sharing options...
Tipex Posted February 5, 2010 Report Share Posted February 5, 2010 There is also a drain hole under the battery, thats the most important one to clear, but obviously involves removal of the battery, and the plate it sits on. Link to comment Share on other sites More sharing options...
