fault scan
johnny11
i got my RS6 scanned last week and it came up with this fault
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0004
Coding: 0010752
Shop #: WSC 02195 785 00200
2 Faults Found:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 002 - Lower Limit Exceeded
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 002 - Lower Limit Exceeded
Readiness: 0000 0000
anyone had this before? or can point me in the right direction
  • 1 month later...
Did you ever get on top of this?
My guess would be faulty air injector pump (air is injected during fast idle at cold engine start) or pinched air pipes. I had an emissions control warning in DIS (yellow engine symbol) in the S8 because the secondary breather pipe had got pinched - any DIS symbols?
Hi Chris,
hopefully yes have got the the bottom of it, the engine managment light came on the dash 2 weeks ago, so called out Audi assist, who came out plug in there tablet pc and scanned, which came up with the same fault codes as above. The guy was very helpful, he made a few phone calls (while looking at the yummy mummys at pick up time) to check his conclusion, which was the secondary air pump. He cleared all the fault codes, and the light hasn`t come back since, but i`ve ordered a secondary air pump and just waiting for this to be delivered, then will get it scanned again to see if this was the problem.
Hows the C6 been?
Edited by johnny11
Hope that's it, and it's a simple fix. I wonder if it was anything to do with the cold weather as well, if you've had no more fault reports from the pump since. Could have been marginal, and a cold spell just tipped it over? :shrug:
The C6 has been an absolute blast - 32k miles in and still love the thing. Had to have the LED running lights replaced because the seals failed and water got in them, and after new tyres and an alignment the rear anti-roll bar was "worn" (I suspect "Bent" would be more accurate) but it still puts a smile on my face every time I drive it.
