benny9876 Posted February 15, 2010 Report Share Posted February 15, 2010 Hey, I own a Golf Gti 2.0 8v. Iv had the car for just over 2 years and in this time iv had 4 coilpacks fitted. For some reason they just keep burning out and i dont know y. Then also sometimes as i come to a stop and im busy braking, "sometimes" the revs just drop and the car switches off and i hav to start it up again. If anyone knows what the solution to this could be plz rply, thanx. Link to comment Share on other sites More sharing options...
cruiser647 Posted February 16, 2010 Report Share Posted February 16, 2010 Hi! Welcome to TSN When was the last time it was serviced? Do you have the correct spark plugs fitted? - Might be worth changing them anyway. Also, clean the throttle body if you can (air intake into the engine), that usually gets filthy with oil/gunk and can block air pass through pipes. Clean it with cloth and either carb cleaner or alcohol! Link to comment Share on other sites More sharing options...
benny9876 Posted February 16, 2010 Author Report Share Posted February 16, 2010 Hey. It was serviced last 16000km ago, but ill sure be replacing the spark plugs and getting the throttle cleaned. I hope this is it, thanx Link to comment Share on other sites More sharing options...
cruiser647 Posted February 17, 2010 Report Share Posted February 17, 2010 You might want ro replace the air filter too. Good luck! Link to comment Share on other sites More sharing options...
burble Posted February 17, 2010 Report Share Posted February 17, 2010 It could be a cam position sensor that's causing the problem, I saw a similar thing on my girlfriends Corsa. Link to comment Share on other sites More sharing options...
benny9876 Posted February 19, 2010 Author Report Share Posted February 19, 2010 i took my car away n found that my throttle was quite dirty, so i got that cleaned n got my forks checked as well as a diagnostic check which brought up 4 fualt codes, of which 3 was erased. Something of a potentiometer, throttle position sensor and something to do with the air flow. car seems to be much better but still monitoring Thanx guys Link to comment Share on other sites More sharing options...
