vaslam1986 Posted March 10, 2010 Report Share Posted March 10, 2010 Hi, I'm having problems with my hood, when i press the power hood button the hood begins to open but the boot lid catch doesn't seem to release It makes a whirring noise, moves a bit then stops....I made a video of the problem to show what i mean by this (link below) ...any ideas anyone??? Link to comment Share on other sites More sharing options...
Chav Posted March 10, 2010 Report Share Posted March 10, 2010 Hi mate, how old is the car? mines a 2006 and the hood has done that occasionally recently...seems to be that the big boot panel is the heaviest, so its that that stops lifting first when the hydraulics feck up. I also get the yellow hood symbol flashing (which you posted somewhere else) Needs dealer attention to check the hydraulics. On mine I also ensure i raise/lower the roof with the engine running...gives more current to the mech giving it a better chance of working ok!! If it stops halfway, raise/lower the roof via the normal button way, and if that doesnt work, manually lift the boot panel and pull the roof. works a treat, but obviously makes you look a plonker in public ! :-) Link to comment Share on other sites More sharing options...
Cupramax Posted March 11, 2010 Report Share Posted March 11, 2010 I've had mine jam up halfway through opening while out and about and looked like a right idiot. With mine the whole lot just stopped in the giant windbreak position. Its done this a couple of times now... not good. Link to comment Share on other sites More sharing options...
magrillz Posted May 25, 2010 Report Share Posted May 25, 2010 Hi guys, My wife's 2003 A4 cab has started doing this. The rear panel starts to lift but then it's as if the hyraulics don't have enough power to fully lift it. If I gently lift the rear panel it then carries on lifting and the roof works fine. The cars just come out of an extended warrany and due to the milleage we couldn't renew. Do you think the hydraulics have gone? Just thought I'd check in case it was a common issues resolved quite cheaply but can't find anything on the net so guess not? Thanks in advance Link to comment Share on other sites More sharing options...
netmonky Posted July 13, 2010 Report Share Posted July 13, 2010 Hi all, Did this get resolved? I have an audi a4 s4 with the same issue :-( ... any pointers? WHere is the res? THanks Mark Link to comment Share on other sites More sharing options...
Cupramax Posted July 15, 2010 Report Share Posted July 15, 2010 Mine was a position sensor which sits in the right hand side mechainism... its either this or the switch itself on the centre console. Link to comment Share on other sites More sharing options...
netmonky Posted August 1, 2010 Report Share Posted August 1, 2010 mine is showing the below ... can anyone help? 1 Fault Found: 02000 - Switch Position 008 - Implausible Signal Link to comment Share on other sites More sharing options...
PetrolDave Posted August 1, 2010 Report Share Posted August 1, 2010 mine is showing the below ... can anyone help?1 Fault Found: 02000 - Switch Position 008 - Implausible Signal See 02000 - Ross-Tech Wiki and Audi A4 (8E) Automatic Roof - Ross-Tech Wiki Link to comment Share on other sites More sharing options...
Cupramax Posted August 2, 2010 Report Share Posted August 2, 2010 mine is showing the below ... can anyone help?1 Fault Found: 02000 - Switch Position 008 - Implausible Signal As I put above your post, if you dont want to spend a fortune letting Audi diagnose it, replace the switch on the centre console and if that doesn't sort it the position sensor 8H0 959 613. Link to comment Share on other sites More sharing options...
netmonky Posted August 2, 2010 Report Share Posted August 2, 2010 Hi, switch in the middle has already been replaced :-). Can I reset sensor values with VAG ? Link to comment Share on other sites More sharing options...
cruiser647 Posted October 30, 2011 Report Share Posted October 30, 2011 Good work Fella! Welcome to TSN. Surprised no-one else suggested stuff. We are usually much better at this than that above! Link to comment Share on other sites More sharing options...
