Mitchet Posted April 13, 2010 Report Share Posted April 13, 2010 Does anyone know what a "Transmission Mount Valve" is? And what does it mean when it's faulty? The car seems to be running fine, but VCDS is reporting the following (even after clearing fault codes): Address 01: Engine Labels: Redir Fail! Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C Component: 3.0L V6TDI A000AG 0020 Revision: --H01--- Serial number: AUX3Z0E2361934 Coding: 0011973 Shop #: WSC 02313 785 00200 2 Faults Found: 006257 - Transmission Mount Valve 2 (N263): Short to Plus P1871 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 1 Mileage: 164709 km Time Indication: 0 Date: 2010.04.05 Time: 17:56:57 Freeze Frame: RPM: 0 /min Torque: 179.4 Nm Speed: 0.0 km/h Voltage: 11.93 V Bin. Bits: 1 Bin. Bits: 1 Bin. Bits: 1 006256 - Transmission Mount Valve 1 (N262): Open Circuit P1870 - 001 - Upper Limit Exceeded Freeze Frame: Fault Status: 01110001 Fault Priority: 0 Fault Frequency: 10 Mileage: 164709 km Time Indication: 0 Date: 2010.04.05 Time: 18:04:25 Freeze Frame: RPM: 840 /min Torque: 70.2 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 11.70 V Bin. Bits: 00010111 Torque: 288.6 Nm Readiness: 0 0 0 0 0 Link to comment Share on other sites More sharing options...
PsYcHe Posted April 13, 2010 Report Share Posted April 13, 2010 no idea.. But interesting that one shows an open circuit and the other shows short to plus. OK, I don't know how these things are wired up, but it almost sounds like an electrical issue (or 1 has failed and it's throwing an error for the other). Link to comment Share on other sites More sharing options...
A8_Tony Posted April 14, 2010 Report Share Posted April 14, 2010 Ben will be along soon :D :notworthy: Link to comment Share on other sites More sharing options...
Mitchet Posted April 14, 2010 Author Report Share Posted April 14, 2010 Sounds promising Link to comment Share on other sites More sharing options...
Limoncello Posted September 8, 2010 Report Share Posted September 8, 2010 Did you find out what "Transmission Mount Valve 1" means, im getting the same error Link to comment Share on other sites More sharing options...
Mitchet Posted September 11, 2010 Author Report Share Posted September 11, 2010 I spoke to one of the parts guys at Boston Audi the other day and he thinks it's a mount that the gearbox sits on. When the car starts, the mount electronically controls the vibration of the engine and gearbox to minimise vibration through the cars body. I'd presume it also does this when the engine is running? Not much info, but he did say it would be expensive to replace (from a labour point if view). The mount itself is around £220 each. I'll speak to my local independent soon and see what they think. Link to comment Share on other sites More sharing options...
Limoncello Posted September 11, 2010 Report Share Posted September 11, 2010 i have a warranty which may cover that so il try to find out more this end Link to comment Share on other sites More sharing options...
varcolac1987 Posted July 25, 2013 Report Share Posted July 25, 2013 hello about that transmision valve did u change it?does that affect the car with anything....i have the same problem with my a8....thank you Link to comment Share on other sites More sharing options...
PsYcHe Posted July 25, 2013 Report Share Posted July 25, 2013 You'll get extra vibration, and it'll cause extra wear and tear on driveshafts, etc. Link to comment Share on other sites More sharing options...
