Transmission Mount Valve Error???
Mitchet
Does anyone know what a "Transmission Mount Valve" is? And what does it mean when it's faulty? The car seems to be running fine, but VCDS is reporting the following (even after clearing fault codes):
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C
Component: 3.0L V6TDI A000AG 0020
Revision: --H01--- Serial number: AUX3Z0E2361934
Coding: 0011973
Shop #: WSC 02313 785 00200
2 Faults Found:
006257 - Transmission Mount Valve 2 (N263): Short to Plus
P1871 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 164709 km
Time Indication: 0
Date: 2010.04.05
Time: 17:56:57
Freeze Frame:
RPM: 0 /min
Torque: 179.4 Nm
Speed: 0.0 km/h
Voltage: 11.93 V
Bin. Bits: 1
Bin. Bits: 1
Bin. Bits: 1
006256 - Transmission Mount Valve 1 (N262): Open Circuit
P1870 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 10
Mileage: 164709 km
Time Indication: 0
Date: 2010.04.05
Time: 18:04:25
Freeze Frame:
RPM: 840 /min
Torque: 70.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.70 V
Bin. Bits: 00010111
Torque: 288.6 Nm
Readiness: 0 0 0 0 0
