Oh cock. D3 parking brake stuck on. Any ideas?
RRH685
I've had intermittent warning lights re the parking brake for a couple of weeks, but haven't taken a lot of notice. It just sounded like the motors weren't working at the same time.
I've gone out to it this morning, tried to disengage the parking brake- nothing. No motor noise or anything.
Any ideas?
Thanks muchly
Simon :)
Mine stopped doing the auto-release after a firmware update.
If they're stuck on, they're a PITA! Mine did it during the winter. I popped the wheel off, disconnected the connectors, give a vigorous spraying with WD40, put it back together and all was well.
Only other option is to dismantle the brake caliper, etc and manually wind it in.
Did you get a satisfactory outcome on this problem?
I've noticed a few times when I lock the car from the door button that the parking brake seems to cycle through a few on and offs. Not the same door button and not every time.
I mentioned it to Audi but they found nothing in the Faults and their Tech had never heard of this happening.
Am I in uncharted waters?
Stew,
Mine does it too - is it perhaps self-adjustment, rather than self-test? It seems like it winds all the way off, then all the way on, then backs off a bit. I wonder if that would take account of pad wear, and always ensure that the amount of time taken to wind on the "handbrake" is within acceptable bounds. I wonder also if there are benefits from winding back and forth - less risk of seizing up, that sort of thing.
Of course: I'm theorising from a position of bugger-all knowledge. I've had calipers in bits, but not *these* calipers. Might well be talking bozwellocks.
I used to leave my parking brake off - car on flat driveway and transmission lock stops it moving anyway. But the I noticed that most times, shortly after I parked the car I would hear the parking brake motors cycling (as described above) several times. I was concerned that this could, perhaps, shorten the life of the motors and started to always park the car with the parking brake selected. Not sure if this is good or bad practice but, so far, no problems (53 plate D3 4.0TDi but with only 53K which I have owned since May 06).
My local friendly Audi man came and wound the rear calipers off, and found that there was nothing left of the rear pads. I've ordered disks and pads and they're being fitted this week.
I'm told the rear brake motors rarely fail... but the handbrake ECU's can be a problem- I'm hoping the disks / pads sort it, and that it had gone in to some sort of 'safety' mode, but suspect it will need an ecu.
  PsYcHe said:
They all seem to do it.. Sometimes it's on for just a quick burst, other times it cycles. Not sure if it's a self test feature or not.
I'm reassured now I know others have had this 'cycling' syndrome.
As I said before the Audi Tech in Aberdoom had never heard of it.... that's worrying though!
Still on warranty for another year anyway!
My error code was something like "rear passenger caliper motor failure" or something like that...
When the pads were changed that one side failed to calibrate or something. I remember them using the computer to move the pads in or something and one worked fine, the other danced around various numbers but never reached 0.
Got a price of £165 for the motor or £465 for the caliper and motor.. should be under warranty, but Evans Halshaw are playing the game with me... we'll see how long they last
does not surprise me, every time mine went into ABZ it has come out with more faults then it went in with, not sure they know one end of an A8 to the other. I've switched to Perth.
Axeboy, did you have to get the entire motor replaced, or do they do just the belt? I've just had the dashboard light up like a christmas tree due to a parking brake problem, ironic given my recent contribution to this very thread. Thought I wasn't going to leave the office last week although, eventually, the brake disengaged. Haven't used it since in fear...
