MarskeBear Posted August 25, 2010 Report Share Posted August 25, 2010 Hi, Have not bough any new buffer pads for my PC for ages so time to invest again, what the latest reccomendations from those in the now? I have had sonus in past with couple of megs. Car has suffered some cosmetic scratch wounds over the last year so needs a good seeing to to get it back to its old glory. Paint work is still in good knick but as i said just needs a little loving. Link to comment Share on other sites More sharing options...
maersk Posted August 25, 2010 Report Share Posted August 25, 2010 I like the Lake County ones but lots seem to like Hexlogic. I quite like the Sonus DAS range too; and to be totally left field I have had good results with Menz polishing pads. Bet those Gulls down by the Ship give the paint a hard time! Link to comment Share on other sites More sharing options...
eldavo69 Posted August 25, 2010 Report Share Posted August 25, 2010 If you can get them the new style megs pads are really nice. They have a lip around them to stop you catching an edge with the backing plate and are machine washable too. I've just picked up a set of 3m pads to try out and will report back Link to comment Share on other sites More sharing options...
MarskeBear Posted August 25, 2010 Author Report Share Posted August 25, 2010 Cheers lads, I might get a couple of each as the good ladys car will need the treatment prior to winter. Its the Turners and Vista Mar for me these days lol. ;-) Link to comment Share on other sites More sharing options...
MarskeBear Posted August 25, 2010 Author Report Share Posted August 25, 2010 Is cleanyourcar.co.uk still good place to buy? Link to comment Share on other sites More sharing options...
maersk Posted August 26, 2010 Report Share Posted August 26, 2010 Yep use Tim a lot. Ah the Vista..............the hill is a bugger after though. Link to comment Share on other sites More sharing options...
NeilB Posted August 26, 2010 Report Share Posted August 26, 2010 I've used the Sonus pads in the past with my PC, but I've invested in some Hex Logic ones for my winter prep over the coming weeks due to the good reports I've read about them. Link to comment Share on other sites More sharing options...
steelwind101 Posted August 27, 2010 Report Share Posted August 27, 2010 As your using the PC i would suggest looking at some pads from the Lake Country range. Esp. the flat, 5.5inches ones. You will get quicker results as they are a small surface and thus less resistance from the PC so you can cut quicker. I dont rate the CSS type to highly though the CSS hand applicators are pretty decent. The Meguiars beige/tan/yellow "polishing" pad is a good durable pad and you can use it with a lot of different grade polishes. IMO, no machine detailing kit should be with out one. Which ever brand you choose i would look to include some kind of "polishing pad" and a "cutting pad". If you want to apply by LSP or zero cut and clean products by machine then finishing pad is your friend. Various brands offer "finessing" and "light cut" and various other things. They are great but only once you know what you will use them for. I dont consider them to be essential. Possibily investing in 2x 2 good pads is better then buying 4 or 4 of which only 2 you will end up using! Geoff Link to comment Share on other sites More sharing options...
P_G Posted September 8, 2010 Report Share Posted September 8, 2010 A recommendation for the Hex logic pads. Just bought some and the results are good, far better than Sonus and miles better than Menzerna on Audi paintwork. Link to comment Share on other sites More sharing options...
steelwind101 Posted September 9, 2010 Report Share Posted September 9, 2010 Hi PG, In what terms do you think they are better in, cut or finish etc? Thanks Geoff Link to comment Share on other sites More sharing options...
maersk Posted September 10, 2010 Report Share Posted September 10, 2010 Which pad/polish combo was best on the Audi? Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted September 10, 2010 Report Share Posted September 10, 2010 I have experience of Sonus, Menzerna and Megs. For correction work I particularly like the Menz pads as they small (not too much load on the DA polisher) and being a bit firmer, seem to break down the abrasives quicker. I have only used them on VAG paint though.Sonus spot pads are a must for intricate areas.Although I favour Menzerna pads, they don't last long. I've had a couple break up and one actually exploded with a bang! - foam everywhere!! I think I had compromised the 'shell' of the pad by damaging the edge on a tailgate logo badge a few minutes prior. Link to comment Share on other sites More sharing options...
