TheBigRedDragon Posted October 20, 2010 Report Share Posted October 20, 2010 Hi all. I bought a 2001 3.7 A8 with 80,000 on the clock about 5 weeks ago and have no end of problems with the gearbox. A week after getting the car the gearbox went into safe mode, then seized completly. Went back to the garage in croydon that i got it from and he got it transferred to a local gearbox specialist to sort and was in there for around a week. ( they said that 2 cogs were actually welded together) Had a new gearbox installed and about a week later it went again, went back to the gearbox specialists as they had given me a 12 month 12,000 mile warranty. 2 weeks on and after countless phone calls chasing them up its still not sorted!! Basicly they re-did the gearbox again, then found that there was somethinig wrong with part of the loom. After sorting that they tried to clear the fault codes off the car so i could have it back, however they couldnt because the car wouldnt let them! They then found that they had forgotten to plug something in so back out came the box again. Sorted that, put it back in and still wouldnt clear the codes so it went across to Audi to be looked at, Audi found that some part that plugs onto the loom ( they did tell me but i cant remember what it was) was faulty and that was why the gearbox was burning out. so got that part and put it in, which meant the box was out again. Now that that is done, yesterday i had them call me and say that while testing the car it was pissing oil out of the gearbox! Reason apparently is the oil pump in the gearbox has to put a manufacturers original part, not a cheaper version. So as it stands now they have ordered the new pump from Audi, which has to come from germany as they have none in the uk and that could take up to 10 days to arrive! So they will have had the car at their garage for longer than i've had it!!! Has anyone ever heard of these problems?? Many Thanks Pete Link to comment Share on other sites More sharing options...
sutherland Posted October 21, 2010 Report Share Posted October 21, 2010 Air flow meter? Link to comment Share on other sites More sharing options...
TheBigRedDragon Posted November 2, 2010 Author Report Share Posted November 2, 2010 Right, collected the car after it being in the garage for over a month and it was running fine. cruised through town and down the M25 nicely. As i pulled away from the traffic lights to come onto the A3, the car went back into safe mode!! limped it into a petrol station nearby and found that i had no reverse, in fact even better than that when i selected reverse or neutral it would try to drive forward! had to turn the engine off to push it backwards and then limped it the rest of the way home. Can anyone help on what this could be, i havent spoken to the garage yet but needless to say i wont be very happy. Have i just bought a duff car? Link to comment Share on other sites More sharing options...
PsYcHe Posted November 3, 2010 Report Share Posted November 3, 2010 I think they should put a new gearbox in for you and probably a new Gearbox Control Unit... The gearboxes can fail, but that sounds pretty spectacular. Link to comment Share on other sites More sharing options...
