Audi A3 not going into 'sleep mode' when locked
I've just bought an Audi A3, and thought I had a simple problem of a defective Hazard Warning Switch which remained illuminated perminently (i.e. didn't switch-off after the normal time dealy).
However, I've now removed the switch, and I think the problem may be the car not going into 'sleep mode' properly. The interior lights & mileage all turn-off when you lock the car, however, having sat inside the locked car I can now hear electrical 'buzzing' from behind the central dash area suggesting some items are remaining live - explaining may battery drain after a couple days of non-driving.
Not really familiar with CAN-bus wiring, but having looked at the Hayes wiring diagram there seems to be a 'Convenience CAN Bus' link to the 'On-board supply control unit'. I'm guessing that the supply control unit is staying live when it should be 'asleep' which is why the Hazard switch is illuminated.
Does this make any sense? Any suggestions on what I should try next? :confused:
I've actually traced the problem to the 'Welcome Home' light switch, the one below the main light switch which holds the sidelights on for 40 seconds after you lock the car.
This switch was remaining illuminated perminantly along with the Hazard Switch.
Disconnecting the connector from the back of this switch has cured all other symptoms, and the car now powers-down and goes into sleep mode properly after the normal delay!
I don't use this switch/feature so will probably not bother to replace it, just leave it disconnected.
