wes68 Posted February 25, 2011 Report Share Posted February 25, 2011 Hi all,im hoping someone out there can help me.My 02 cabriolet has developed an intermittant missfire,very irritating! A friend of mine has done a vagcom sweep on it & came up with a couple of codes: 16684-random/multiple cylinder misfire detected (po300-001-upper limit exceeded-intermittant) & 16686-cylinder 2 misfire detected(po302-001-upper limit exceeded-intermittant) those were on the engine check.Another one came up on the auto hvac check & im curious if they are linked: 00819-high pressure sensor(g65) 07-10-signal too low-intermittant.Any help would be much appreciated. Ian Link to comment Share on other sites More sharing options...
Mook Posted February 25, 2011 Report Share Posted February 25, 2011 Welcome to Tyresmoke What engine is it? If it's a 1.8T it will almost definitely be one or more of the coil packs. Quick to replace and about £25 each. There's one per cylinder. Link to comment Share on other sites More sharing options...
wes68 Posted March 1, 2011 Author Report Share Posted March 1, 2011 Welcome to Tyresmoke What engine is it? If it's a 1.8T it will almost definitely be one or more of the coil packs. Quick to replace and about £25 each. There's one per cylinder. Its the 2.4 v6,ive replaced the plug leads but it has 3 coils on it. One for each pair of cylinders,any known probs with these? Link to comment Share on other sites More sharing options...
