thebrickcounter Posted April 11, 2011 Report Share Posted April 11, 2011 Is there a definitive list per car for all settings / faults, as they all seem to be scattered here and everywhere? thx Link to comment Share on other sites More sharing options...
Scotty Posted April 11, 2011 Report Share Posted April 11, 2011 Since they're always being discovered and normally by people on car specific forums then it's not often you'll find a complete collection. A guy in the US did one recently for the B8 A4 and already that's struggling to keep up to date. The closest you may get to a complete list for all cars is ross-tech's wiki but it's certainly not definitive and if you just looked at that you'd miss out on so much. What car have you got and then we may be able to assist a bit more? Link to comment Share on other sites More sharing options...
thebrickcounter Posted April 13, 2011 Author Report Share Posted April 13, 2011 Hi I have an A$ Cab B7. I have had a fault with the roof, in that it appears to be dead with no yellow normal roof opening light even displaying. Ive just got a Vag.com cable and software. upon plugging it reals off loads of numbers which dont mean anything to me. Also when I click comford mode and click button 38-Roof electrics it comes up with a not reading or something like that. the other codes are; VCDS Version: Release 10.6.2 Data version: 20101123 Wednesday,13,April,2011,20:47:53:36838 Chassis Type: 8H - Audi Cabrio B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 26 36 37 45 46 55 56 57 63 65 67 73 75 76 77 VIN: WAUZZZ8H57K000471 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 8E0 910 115 Q HW: 8E0 907 115 D Component: 2.0l R4/4V TFSI 0030 Revision: --H10--- Serial number: Coding: 011C000302070120 Shop #: WSC 01211 210 12345 VCID: 2F660F3881475A64 6 Faults Found: 006549 - Can't Decode, CODE File Not Loaded! P1995 -- 004 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Mileage: 76912 km Time Indication: 0 Freeze Frame: RPM: 1806 /min Load: 60.4 % Speed: 21.0 km/h Temperature: 72.0°C Temperature: 15.0°C Absolute Pres.: 1000.0 mbar Voltage: 14.097 V 005635 - Can't Decode, CODE File Not Loaded! P1603 -- 002 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: -40.0°C Temperature: -40.0°C Absolute Pres.: 0.0 mbar Voltage: 0.000 V 049521 - Can't Decode, CODE File Not Loaded! U0171 -- 008 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 4 Mileage: 84462 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 81.0°C Temperature: 66.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 049413 - Can't Decode, CODE File Not Loaded! U0105 -- 008 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 84462 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 82.0°C Temperature: 66.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 049460 - Can't Decode, CODE File Not Loaded! U0134 -- 008 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 84462 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 81.0°C Temperature: 66.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V 049417 - Can't Decode, CODE File Not Loaded! U0109 -- 008 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 84462 km Time Indication: 0 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 81.0°C Temperature: 66.0°C Absolute Pres.: 1000.0 mbar Voltage: 11.938 V Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01J-927-156.lbl Part No SW: 8E1 910 155 HW: 01J 927 156 HT Component: V30 01J 2.0TFSI RdW 0030 Revision: 00000008 Serial number: 00000000926618 Coding: 0000001 Shop #: WSC 44555 001 00001 VCID: E3CE33081D0F2E04 1 Fault Found: 18258 - Can't Decode, CODE File Not Loaded! P1850 -- 000 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Time Indication: 0 Freeze Frame: RPM: 96 /min RPM: 0 /min (no units): 1.0 Torque: 0.0 Nm Temperature: 78.0°C T.B. Angle: 0.0° Bin. Bits: 0101 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.lbl Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK Component: ESP8 front H05 0120 Revision: 00000000 Serial number: 00000000000000 Coding: 0004525 Shop #: WSC 00672 785 00200 VCID: 2854E424A4A90D5C 5 Faults Found: 01826 - Can't Decode, CODE File Not Loaded! 000 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 12 Reset counter: 13 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4222 Hex Value: 0x0024 Hex Value: 0x0194 Hex Value: 0x0000 01315 - Can't Decode, CODE File Not Loaded! 004 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 13 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0222 Hex Value: 0x0013 Hex Value: 0x8592 Hex Value: 0x0000 01213 - Can't Decode, CODE File Not Loaded! 000 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 1 Fault Frequency: 1 Reset counter: 13 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4222 Hex Value: 0x0002 Hex Value: 0x8192 Hex Value: 0x0000 01319 - Can't Decode, CODE File Not Loaded! 004 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 1 Reset counter: 13 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4222 Hex Value: 0x0013 Hex Value: 0x4492 Hex Value: 0x0000 00792 - Can't Decode, CODE File Not Loaded! 004 -- Can't Decode, CODE File Not Loaded! - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 13 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4222 Hex Value: 0x001E Hex Value: 0x4392 Hex Value: 0x0000 Link to comment Share on other sites More sharing options...
PetrolDave Posted April 15, 2011 Report Share Posted April 15, 2011 What cable do you have? It looks like your VCDS (old name was VAG-COM not vag.com) installation looks faulty as it cannot read the CODE files, I'd be tempted to uninstall and re-install VCDS and try again. Link to comment Share on other sites More sharing options...
