Tyre marks removal
chips*
  • 2 weeks later...
Removing dried -on rubber
Use a safe solvent to remove burned on rubber; that does not contain any harmful components (heptanes or xylene or hydrocarbon aliphatic solvents; Autoglym Intensive Tar Remover, Stoner™ Tarminator, or Simple Green® Aircraft & Precision Cleaner that simply emulsifies and dissolves the rubber, then use a plastic razor blade to remove debris.
If this does not remove the rubber try a 3M Eraser wheel – this 4-inch diameter wheel is made from a soft white polymer, which looks and feels like rubber. 3M Stripe and Decal Remover
That's the one that makes your car fireproof as well isn't it?
Yes, apparently they used it in all the Knight Rider episodes to help protect Kitt from bullet and explosive damage too... the guy had a headset and everything, so I'm sure it must be true...
