PeterS Posted June 13, 2011 Report Share Posted June 13, 2011 Over the last few days my A4 has stopped 'seeing' my iPod. Now, the iPod still works fine in the A3, and the iPod kit in the A4 was a factory fit option. However the RNS-E in the A4 is a retrofit (though it's been there for around 3 years, fully functioning) The error message that comes on the DIS when I select 'changer' (which is how the RNS-E sees the iPod adapter) is No Mag, which I assume means it can't 'see' the iPod. I Is it likely to be as simple as a loose connection between the iPod adaptor and the back of the RNS-E ? Is there anything else that can actually go wrong with the iPod kit :confused: FWIW the iPod generally lives in the car; it's not constantly being moved between cars / car and house, so the connections shouldn't be worn I don't think Thanks Peter Link to comment Share on other sites More sharing options...
craigyb Posted June 13, 2011 Report Share Posted June 13, 2011 No mag suggests that the Ipod kit to RNS-E is functional, but the connection between the Ipod and kit is the faulty part, so probably the connector inside the dock. Link to comment Share on other sites More sharing options...
PeterS Posted June 13, 2011 Author Report Share Posted June 13, 2011 Thanks Will take a closer look in the glovebox tomorrow Peter Link to comment Share on other sites More sharing options...
