dcm017 Posted June 17, 2011 Report Share Posted June 17, 2011 I have a 2005 A6 3.0 TDI Avant Quattro. The MMI system has stopped working. The initial splash logo comes up on the display but then all goes blank, and the radio CD and SatNav do nothing. I have done a VagCom scan as below. It shows the sound system having an electrical error and optical error, and also the radio as havng an optical error. The scan shows other errors too but it may be that they are all interrelated, and the car actually drives well. Any suggestions as to what might be wrong? Thanks ................................................... Sunday,12,June,2011,10:10:17:29408 VCDS Version: Beta 11.3.0 Data version: 20110601 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Control Module Part Number: 4F0 910 468 A Component and/or Version: Gateway H10 0060 Optical Bus Diagnostic : Standard Controller Electrical Optical 19-CAN Gateway OK OK 07-Control Head(High/D3) OK OK 0E-Media Player 1 OK OK 77-Telephone OK OK 47-Sound System ERROR ERROR 56-Radio OK ERROR 37-Navigation OK OK ************************************************************ -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4F0 Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56 61 62 72 76 77 VIN: WAUZZZ4F76N007875 Mileage: 152520km/94771miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: Cannot be reached 1100 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 401 A HW: 4F0 907 401 B Component: 3.0L V6TDI G000AG 0020 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 02335 785 00200 VCID: 1A3062B7A9BA No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 B HW: 09L 927 156 A Component: AG6 09L 3.0lTDI RdW 0030 Revision: --H01--- Serial number: 4012849 Coding: 0000001 Shop #: WSC 02335 785 00200 VCID: 234E5F539EF0 6 Faults Found: 062245 - Unknown Error Code U3325 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 151442 km Time Indication: 0 Date: 2011.04.30 Time: 15:23:33 Freeze Frame: RPM: 416 /min RPM: 0 /min RPM: 0 /min (no units): 1.0 (no units): 25.0 Temperature: 81.0°C T.B. Angle: 0.0° 049682 - Steering Column Control Module: No Communications U0212 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 0 km Time Indication: 0 053259 - Invalid Data Received from Control Module for Access/Start Authorization U100B - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 0 km Time Indication: 0 049478 - No Communication with Diagnostic Gateway U0146 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 40 Mileage: 0 km Time Indication: 0 005889 - Transmission Control Unit: Locked P1701 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 0 km Time Indication: 0 049448 - No Communications with Parking Brake Control Module U0128 - 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 40 Mileage: 151458 km Time Indication: 0 Date: 2005.02.20 Time: 08:38:10 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H03 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020872 Shop #: WSC 02335 785 00200 VCID: 2D5AB96BC834 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0220 Revision: 31050601 Serial number: 10600300142999 Coding: 0000147 Shop #: WSC 00294 210 91489 VCID: E3CE9F535E70 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H44 0070 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H39 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F2 820 043 C Component: KLIMABETAETIGUNGH11 0150 Revision: 00000025 Serial number: 00000000119180 Coding: 0001302 Shop #: WSC 02335 785 00200 VCID: DBBEA7B36600 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0000101 Shop #: WSC 02335 785 00200 VCID: E6C88647AD42 Subsystem 1 - Part No: 4F2 910 113 Component: Wischer AudiC6 H04 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 C HW: 4F0 959 655 B Component: 3E AIRBAG AUDI8RH29 0230 Revision: 06H29000 Serial number: 0037LD0651X3 Coding: 0013125 Shop #: WSC 02327 785 00200 VCID: 27564B43EAC8 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenksäulenmodul H07 0230 Revision: 00H07000 Serial number: 90026050660142 Coding: 0102142 Shop #: WSC 02335 785 00200 VCID: E6C88647AD42 Part No: XXXXXXXXXXX Component: Lenkradmodul H06 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 A HW: 4F0 920 980 M Component: KOMBIINSTR. M73 H15 0630 Revision: 00700000 Serial number: 4PX53LH35 Coding: 2049443 Shop #: WSC 00294 210 96943 VCID: 2142555B84EC No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H10 0060 Revision: 10 Serial number: 12008053050049 Coding: ECFE53C41B3104 Shop #: WSC 02335 785 00200 VCID: 27564B43EAC8 1 Fault Found: 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 106 Mileage: 150941 km Time Indication: 0 Date: 2011.04.22 Time: 15:38:47 ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 793 B Component: TSG FA H11 0040 Revision: 00000000 Serial number: qXB Coding: 0001562 Shop #: WSC 02335 785 00200 VCID: 29524D7BFCDC No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H18 0120 Revision: 01200018 Serial number: 01003371230000 Coding: 0000755 Shop #: WSC 02335 785 00200 VCID: 2E58BE67C532 Component: Sounder No Answer Part No: 4F0 910 177 Component: Innenraumueberw.H01 0020 3 Faults Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 167 Mileage: 74034 km Time Indication: 0 02071 - Local Databus 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 170 Mileage: 151551 km Time Indication: 0 01135 - Interior Monitoring Sensors 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 170 Mileage: 151551 km Time Indication: 0 Date: 2005.02.27 Time: 04:30:49 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000075804 Coding: 0001103 Shop #: WSC 02335 785 00200 VCID: DEB8AEA77512 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 792 B Component: TSG BF H11 0040 Revision: 00000000 Serial number: ˜(S Coding: 0001562 Shop #: WSC 02335 785 00200 VCID: 29524D7BFCDC 1 Fault Found: 00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 84 Reset counter: 166 Mileage: 150944 km Time Indication: 0 Date: 2011.04.23 Time: 09:11:13 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0000321 Shop #: WSC 02334 785 00200 VCID: DDBAA9AB7814 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H12 0470 Revision: 00000000 Serial number: 00000000004990 Shop #: WSC 00958 210 08852 VCID: 234E5F539EF0 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 1503141286 Coding: 344630393135313035442056413031353033313431323836 Shop #: WSC 00000 384 00290 5 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 18 Mileage: 150941 km Time Indication: 0 Date: 2011.04.22 Time: 15:53:51 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 16 Mileage: 150944 km Time Indication: 0 Date: 2011.04.22 Time: 20:57:57 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 16 Mileage: 150944 km Time Indication: 0 Date: 2011.04.22 Time: 20:58:07 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 16 Mileage: 150944 km Time Indication: 0 Date: 2011.04.22 Time: 20:58:17 02272 - Quiescent Current Stage 1 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Mileage: 151458 km Time Indication: 0 Date: 2005.02.12 Time: 13:04:34 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 795 A Component: TSG HL H11 0030 Coding: 0001026 Shop #: WSC 02335 785 00200 VCID: 2A50B277F9DA No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 794 A Component: TSG HR H11 0030 Coding: 0001026 Shop #: WSC 02335 785 00200 VCID: 2A50B277F9DA No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 A HW: 4F0 919 283 A Component: Parkhilfe 8-Kan H12 0030 Revision: 06.00.55 Serial number: 00067811820507 Coding: 0001016 Shop #: WSC 02335 785 00200 VCID: 22405A5781EA 1 Fault Found: 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 2 Reset counter: 40 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 77: Telephone Cannot be reached End --------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
craigyb Posted June 17, 2011 Report Share Posted June 17, 2011 Looks like a straightforward amp fault to me. And as you have said you have an Avant, have you checked the left side of the boot for water damage behind the MMI access panel, ususally looks like white staining on the silver MMI parts. Link to comment Share on other sites More sharing options...
dcm017 Posted June 17, 2011 Author Report Share Posted June 17, 2011 Looks like a straightforward amp fault to me. And as you have said you have an Avant, have you checked the left side of the boot for water damage behind the MMI access panel, ususally looks like white staining on the silver MMI parts. Many thanks for quick reply. The fault started a month ago during very dry weather so I would be surprised if it is water damage, but will check tonight. Is the "amp" the part number 4F0 035 541 B? Sounds expensive. Link to comment Share on other sites More sharing options...
craigyb Posted June 17, 2011 Report Share Posted June 17, 2011 The water comes from your rear wash wipe pipe, so wet weather has no impact. Check the rear wash wipe functionality. 541 B is the radio, amps usually end in 223 or 225 and is the top module in the rack in the boot. Link to comment Share on other sites More sharing options...
dcm017 Posted June 18, 2011 Author Report Share Posted June 18, 2011 The water comes from your rear wash wipe pipe, so wet weather has no impact. Check the rear wash wipe functionality.541 B is the radio, amps usually end in 223 or 225 and is the top module in the rack in the boot. Thank you. The wash wipe functionality is poor and in the process of checking it (as you suggest) leaks all over the amp. The w/w has always been ropey and I've just put up with it. I have now removed the amp and though it doesn't look too bad on the outside I guess that over time water has taken its toll inside. Time to replace it - are they repairable? Link to comment Share on other sites More sharing options...
craigyb Posted June 18, 2011 Report Share Posted June 18, 2011 I would get the wash wipe pipe work repaired ASAP just in case you pull the lever again and poor more water in as you have the radio and DVD nav below the amp and it can get very expensive when all 3 are water logged. Never tried to repair one, I should imagine water has done coonsiderable damage at a component level, so easier to replace. You can buy second hand ones on ebay between £100-400 depending on if it is BOSE or not. But you cannot install fully it as the amp has component protection, when you install it the sound will cut out on one half until CP is removed by a dealership. It may also need coding to suit your vehicle unless it has come out of an identical spec car. Things like, leather, engine type, RHD have to be coded into the amp. Link to comment Share on other sites More sharing options...
dcm017 Posted June 18, 2011 Author Report Share Posted June 18, 2011 I would get the wash wipe pipe work repaired ASAP just in case you pull the lever again and poor more water in as you have the radio and DVD nav below the amp and it can get very expensive when all 3 are water logged.Never tried to repair one, I should imagine water has done coonsiderable damage at a component level, so easier to replace. You can buy second hand ones on ebay between £100-400 depending on if it is BOSE or not. But you cannot install fully it as the amp has component protection, when you install it the sound will cut out on one half until CP is removed by a dealership. It may also need coding to suit your vehicle unless it has come out of an identical spec car. Things like, leather, engine type, RHD have to be coded into the amp. It's a Bose one (4F0 035 223 A) so it will probably cost near the upper end of that bracket. I have a Vagcom but see that visiting the dealer may have to be done to remove the CP. Thanks for all your help. Link to comment Share on other sites More sharing options...
craigyb Posted June 18, 2011 Report Share Posted June 18, 2011 I found a BOSE amp for £120 on ebay a few weeks back. Link to comment Share on other sites More sharing options...
dcm017 Posted June 22, 2011 Author Report Share Posted June 22, 2011 I found a BOSE amp for £120 on ebay a few weeks back. I have fixed the wash/wipe pipework. The water had got into the wiper mechanism and messed it up although the motor itself worked and is just about fixable, but I shall renew it soon as I doubt it will last long. As I couldn't see a BOSE amp for this model for sale online I thought that I had nothing to lose by trying to repair the damaged one. I opened it up and the PCB was badly affected by water damage. However I cleaned it all up with acetone and a small brush and it came up fairly well. I dried it out, put it all back and tried it out - no change. As if it were likely. However next morning it worked first time and radio, CD, Satnav, telephone etc all functioned perfectly. Wow. 3 days later all still well. A VagCom scan still shows a problem (as below) so I don't know if the VagCom is showing a false error or there really is a continuing problem. Hopefully I can now ignore it! Wednesday,22,June,2011,21:35:04:29408 VCDS Version: Beta 11.3.0 Data version: 20110601 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Control Module Part Number: 4F0 910 468 A Component and/or Version: Gateway H10 0060 Optical Bus Diagnostic : Standard Controller Electrical Optical 19-CAN Gateway OK OK 07-Control Head(High/D3)OK OK 0E-Media Player 1 OK OK 77-Telephone OK OK 47-Sound System ERROR ERROR 56-Radio OK OK 37-Navigation OK OK ************************************************************ -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Gateway Installation List: 4F0 910 468 A 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 4F0 910 401 A HW: 4F0 907 401 B Component: 3.0L V6TDI G000AG 0020 Revision: --H01--- Serial number: Coding: 0011372 Shop #: WSC 02335 785 00200 VCID: 1A3062B7A9BA No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4F1 910 156 B HW: 09L 927 156 A Component: AG6 09L 3.0lTDI RdW 0030 Revision: --H01--- Serial number: 4012849 Coding: 0000001 Shop #: WSC 02335 785 00200 VCID: 234E5F539EF0 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.lbl Part No SW: 4F0 910 517 L HW: 4F0 614 517 L Component: ESP 8.0 quattro H03 0090 Revision: 00000000 Serial number: 00000000000000 Coding: 0020872 Shop #: WSC 02335 785 00200 VCID: 2D5AB96BC834 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl Part No SW: 4F0 910 852 HW: 4F0 905 852 B Component: FBSAUDIC6 ELV H30 0220 Revision: 31050601 Serial number: 10600300142999 Coding: 0000147 Shop #: WSC 00294 210 91489 VCID: E3CE9F535E70 Part No: 4F0 910 131 E Component: FBSAUDIC6 EZS H44 0070 Part No: 4F0 910 220 D Component: FBSAUDIC6 IDG H39 0040 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl Part No SW: 4F1 910 732 D HW: 4E0 035 729 Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 392CQ057514294 Coding: 0001002 Shop #: WSC 02335 785 00200 VCID: 254A414B90C4 Part No: 4F0 910 609 B Component: Bedienteil MMIC6H03 0010 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 4F0-910-043.lbl Part No SW: 4F0 910 043 HW: 4F2 820 043 C Component: KLIMABETAETIGUNGH11 0150 Revision: 00000025 Serial number: 00000000119180 Coding: 0001302 Shop #: WSC 02335 785 00200 VCID: DBBEA7B36600 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4F0-910-279.lbl Part No SW: 4F0 910 279 HW: 4F0 907 279 Component: ILM Fahrer H14 0080 Revision: 00000000 Serial number: 4F0907279 Coding: 0000101 Shop #: WSC 02335 785 00200 VCID: E6C88647AD42 Subsystem 1 - Part No: 4F2 910 113 Component: Wischer AudiC6 H04 0150 Coding: 00062736 Shop #: WSC 02335 Subsystem 2 - Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00141886 Shop #: WSC 02335 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBE7136005 Shop #: WSC 00000 000 00000 VCID: 1C3C64AFA38E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4F0-910-655-8R.lbl Part No SW: 4F0 910 655 C HW: 4F0 959 655 B Component: 3E AIRBAG AUDI8RH29 0230 Revision: 06H29000 Serial number: 0037LD0651X3 Coding: 0013125 Shop #: WSC 02327 785 00200 VCID: 27564B43EAC8 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4F0-910-549.lbl Part No SW: 4F0 910 549 HW: 4F0 953 549 A Component: Lenks‰ulenmodul H07 0230 Revision: 00H07000 Serial number: 90026050660142 Coding: 0102142 Shop #: WSC 02335 785 00200 VCID: E6C88647AD42 Part No: XXXXXXXXXXX Component: Lenkradmodul H06 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4F0-910-xxx-17.lbl Part No SW: 4F0 910 930 A HW: 4F0 920 980 M Component: KOMBIINSTR. M73 H15 0630 Revision: 00700000 Serial number: 4PX53LH35 Coding: 2049443 Shop #: WSC 00294 210 96943 VCID: 2142555B84EC No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4F0-910-468.lbl Part No SW: 4F0 910 468 A HW: 4F0 907 468 D Component: Gateway H10 0060 Revision: 10 Serial number: 12008053050049 Coding: ECFE53C41B3104 Shop #: WSC 02335 785 00200 VCID: 27564B43EAC8 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H44 1060 Revision: 00000000 Serial number: 305CS057578292 Shop #: WSC 02335 785 00200 VCID: 3B7E87330640 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 793 B Component: TSG FA H11 0040 Revision: 00000000 Serial number: qXB Coding: 0001562 Shop #: WSC 02335 785 00200 VCID: 29524D7BFCDC No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4F0-910-289.lbl Part No SW: 4F0 910 289 G HW: 4F0 907 289 G Component: Komfortgeraet H18 0120 Revision: 01200018 Serial number: 01003371230000 Coding: 0000755 Shop #: WSC 02335 785 00200 VCID: 2E58BE67C532 Component: Sounder No Answer Part No: 4F0 910 177 Component: Innenraumueberw.H01 0020 1 Fault Found: 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 187 Mileage: 74034 km Time Indication: 0 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4F0-910-223-BO.lbl Part No SW: 4F0 910 223 J HW: 4F0 035 223 G Component: DSP-High C6 H09 0240 Revision: PROD_01 Serial number: 00000000778878 Coding: 0000113 Shop #: WSC 02335 785 00200 VCID: 254A414B90C4 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl Part No SW: 4F0 910 280 HW: 4F0 907 280 A Component: ILM Beifahrer H09 0050 Revision: Serial number: 00000000075804 Coding: 0001103 Shop #: WSC 02335 785 00200 VCID: DEB8AEA77512 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl Part No SW: 4F0 910 793 B HW: 4F0 959 792 B Component: TSG BF H11 0040 Revision: 00000000 Serial number: ò(S Coding: 0001562 Shop #: WSC 02335 785 00200 VCID: 29524D7BFCDC No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4F0-910-801.lbl Part No SW: 4F0 910 801 HW: 4F0 907 801 Component: EPB C63C0030 H03 0030 Revision: C63C0030 Coding: 0000321 Shop #: WSC 02334 785 00200 VCID: DDBAA9AB7814 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4F0 035 541 B Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 394CY057528628 Coding: 0000001 Shop #: WSC 02335 785 00200 VCID: 3162A51BD40C No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4F0-910-181.lbl Part No SW: 4F0 910 181 E HW: 4F0 915 181 A Component: ENERGIEMANAGER H12 0470 Revision: 00000000 Serial number: 00000000004990 Shop #: WSC 00958 210 08852 VCID: 234E5F539EF0 Subsystem 1 - Part No: 4F0 915 105 D Component: von VA0 1503141286 Coding: 344630393135313035442056413031353033313431323836 Shop #: WSC 00000 384 00290 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 795 A Component: TSG HL H11 0030 Coding: 0001026 Shop #: WSC 02335 785 00200 VCID: 2A50B277F9DA No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4F0-910-795.lbl Part No SW: 4F0 910 795 A HW: 4F0 959 794 A Component: TSG HR H11 0030 Coding: 0001026 Shop #: WSC 02335 785 00200 VCID: 2A50B277F9DA No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4Fx-910-283.lbl Part No SW: 4F0 910 283 A HW: 4F0 919 283 A Component: Parkhilfe 8-Kan H12 0030 Revision: 06.00.55 Serial number: 00067811820507 Coding: 0001016 Shop #: WSC 02335 785 00200 VCID: 22405A5781EA No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H10 1130 Revision: 00000000 Serial number: 00000007543929 Coding: 0010900 Shop #: WSC 00000 000 00000 VCID: 2C5CB46FF32E No fault code found. End --------------------------------------------------------------------- -------------------------------------------------------------------------------- ************************************************************ Link to comment Share on other sites More sharing options...
944Turbo Posted January 12, 2012 Report Share Posted January 12, 2012 I am suffering a similar problem, I knew my rear wash was leaking so wasn't using it but took the car in for service and forgot to tell them this time, they soaked the AMP etc. and it no longer works. (3.0tdi Avant ) They took out the amp and dried it but the mmi is not working, I have a blank screen, if I turn it on I get an Audi MMI display then it goes blank again (MMI high Bose amp, cd, radio and TV installed) With a VAG COM optical loop test I get a failure on the 47 sound system Optical (all other electrical and opticals ok). I would like to have a closer look at the various modules, Can I remove and disconnect the components and put them back in without affecting the CP? Any input appreciated, thanks, Tony Link to comment Share on other sites More sharing options...
dcm017 Posted January 13, 2012 Author Report Share Posted January 13, 2012 I am quite sure that you can remove and disconnect the components and replacing the same ones without affecting the CP. I know that there is now a recall by audi which covers the problem. Eventually when I had to take my car to the main dealer to reset the CP they told me that the recent recall allowed them to replace the amplifier (which had been soaked - many times) and they put a new amp in. As they cost nearly £800 new i was relieved. I suggest you call your main dealer to discuss. Link to comment Share on other sites More sharing options...
944Turbo Posted January 23, 2012 Report Share Posted January 23, 2012 Thanks, not sure how much help they will be as I use a specialist for servicing and I bought the car used from outside of the dealer network, worth a try though I guess! Link to comment Share on other sites More sharing options...
familymangreg Posted March 8, 2012 Report Share Posted March 8, 2012 Hi all, I've just had a Bose amp and some wiring replaced completely free of charge by Audi following water ingress damage from a rear wash hose. See this thread: MMI / BOSE Sound issues If anyone finds this thread and is having the same problems, suggest you take it up with Audi UK customer service as a first point of contact. :wq Link to comment Share on other sites More sharing options...
gti123 Posted April 14, 2012 Report Share Posted April 14, 2012 Hi, Have a 2006 Avant with a MMI fault , none of the lights on the panel by the gearshift light up and nothing will turn on. In the back the Navigation will light up and you can eject the disc. I ran a optical test on vag com and it says error in all columns, the only ecu I can communicate with is the Can gateway any ideas where I can start here ? Link to comment Share on other sites More sharing options...
familymangreg Posted April 14, 2012 Report Share Posted April 14, 2012 Hi, Any sign of water ingress in the boot above the nav unit? My local garage bypassed the BOSE amp above the nav unit to diagnose. Everything worked fine then, albeit without any sound. If you are based anywhere near east Yorkshire I know a garage who could help at a very reasonable cost. :wq Hi,Have a 2006 Avant with a MMI fault , none of the lights on the panel by the gearshift light up and nothing will turn on. In the back the Navigation will light up and you can eject the disc. I ran a optical test on vag com and it says error in all columns, the only ecu I can communicate with is the Can gateway any ideas where I can start here ? Link to comment Share on other sites More sharing options...
Mack04 Posted April 14, 2014 Report Share Posted April 14, 2014 Guys, just a quick one on this, my A6 2005 Amp was only working out of one speaker but the bass was fine across them all, I have replaced it with a unit via ebay but now I don't get any sound at all, is this now in Component Protection mode? Link to comment Share on other sites More sharing options...
cruiser647 Posted April 14, 2014 Report Share Posted April 14, 2014 I think most of the stuff is in Component Protection. I think you'll need VAG-Com to reset it. Link to comment Share on other sites More sharing options...
chasdrury Posted April 14, 2014 Report Share Posted April 14, 2014 I think most of the stuff is in Component Protection. I think you'll need VAG-Com to reset it. Component protection can only be removed at a dealer.. could it just be coded incorrectly? Link to comment Share on other sites More sharing options...
a6sline Posted March 27, 2015 Report Share Posted March 27, 2015 i have the same problem, well almost i have an 2006 3.00 tdi v6 sline SALOON a couple of weeks ago i noticed the cd player sort of faded in and out which had never happened before then one day the cd radio satnav etc wasen't working i don't know why but i wiggled the key in the ignition a bit and it came back on i don't know if that was just coincedence becouse the next day it was all dead and hesen't come back on since the display screen does come on if i press the volume button down as if to turn radio on i get the logo with the rings and the audi mmi messsege but then it goes blank the multi changer in glove box is still on i can eject and load the discs the dvd nav drive thingy in the boot stil ejects and loads the disc as well if anyone has any ideas or advice that would be very much apriciated thanks in advance Link to comment Share on other sites More sharing options...
