A6 MMI problem
dcm017
I have a 2005 A6 3.0 TDI Avant Quattro. The MMI system has stopped working. The initial splash logo comes up on the display but then all goes blank, and the radio CD and SatNav do nothing. I have done a VagCom scan as below. It shows the sound system having an electrical error and optical error, and also the radio as havng an optical error. The scan shows other errors too but it may be that they are all interrelated, and the car actually drives well.
Any suggestions as to what might be wrong?
Thanks
Sunday,12,June,2011,10:10:17:29408
VCDS Version: Beta 11.3.0
Data version: 20110601
Control Module Part Number: 4F0 910 468 A
Component and/or Version: Gateway H10 0060
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
77-Telephone OK OK
47-Sound System ERROR ERROR
56-Radio OK ERROR
37-Navigation OK OK
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
61 62 72 76 77
VIN: WAUZZZ4F76N007875 Mileage: 152520km/94771miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 02335 785 00200
VCID: 1A3062B7A9BA
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 4012849
Coding: 0000001
VCID: 234E5F539EF0
6 Faults Found:
062245 - Unknown Error Code
U3325 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 151442 km
Time Indication: 0
Date: 2011.04.30
Time: 15:23:33
Freeze Frame:
RPM: 416 /min
RPM: 0 /min
RPM: 0 /min
(no units): 1.0
(no units): 25.0
Temperature: 81.0°C
T.B. Angle: 0.0°
049682 - Steering Column Control Module: No Communications
U0212 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
053259 - Invalid Data Received from Control Module for Access/Start Authorization
U100B - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
005889 - Transmission Control Unit: Locked
P1701 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
049448 - No Communications with Parking Brake Control Module
U0128 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 151458 km
Time Indication: 0
Date: 2005.02.20
Time: 08:38:10
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 2D5AB96BC834
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300142999
Coding: 0000147
Shop #: WSC 00294 210 91489
VCID: E3CE9F535E70
Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H44 0070
Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 C
Component: KLIMABETAETIGUNGH11 0150
Revision: 00000025 Serial number: 00000000119180
Coding: 0001302
VCID: DBBEA7B36600
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0000101
VCID: E6C88647AD42
Subsystem 1 - Part No: 4F2 910 113
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1
Cannot be reached
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 C HW: 4F0 959 655 B
Component: 3E AIRBAG AUDI8RH29 0230
Revision: 06H29000 Serial number: 0037LD0651X3
Coding: 0013125
Shop #: WSC 02327 785 00200
VCID: 27564B43EAC8
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050660142
Coding: 0102142
VCID: E6C88647AD42
Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
Component: KOMBIINSTR. M73 H15 0630
Revision: 00700000 Serial number: 4PX53LH35
Coding: 2049443
Shop #: WSC 00294 210 96943
VCID: 2142555B84EC
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 12008053050049
Coding: ECFE53C41B3104
VCID: 27564B43EAC8
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 106
Mileage: 150941 km
Time Indication: 0
Date: 2011.04.22
Time: 15:38:47
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H11 0040
Revision: 00000000 Serial number: qXB
Coding: 0001562
VCID: 29524D7BFCDC
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01003371230000
Coding: 0000755
VCID: 2E58BE67C532
Component: Sounder No Answer
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
3 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 167
Mileage: 74034 km
Time Indication: 0
02071 - Local Databus
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 151551 km
Time Indication: 0
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 151551 km
Time Indication: 0
Date: 2005.02.27
Time: 04:30:49
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000075804
Coding: 0001103
VCID: DEB8AEA77512
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H11 0040
Revision: 00000000 Serial number: ˜(S
Coding: 0001562
VCID: 29524D7BFCDC
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 84
Reset counter: 166
Mileage: 150944 km
Time Indication: 0
Date: 2011.04.23
Time: 09:11:13
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: DDBAA9AB7814
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H12 0470
Revision: 00000000 Serial number: 00000000004990
Shop #: WSC 00958 210 08852
VCID: 234E5F539EF0
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1503141286
Coding: 344630393135313035442056413031353033313431323836
Shop #: WSC 00000 384 00290
5 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 18
Mileage: 150941 km
Time Indication: 0
Date: 2011.04.22
Time: 15:53:51
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 150944 km
Time Indication: 0
Date: 2011.04.22
Time: 20:57:57
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 150944 km
Time Indication: 0
Date: 2011.04.22
Time: 20:58:07
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Mileage: 150944 km
Time Indication: 0
Date: 2011.04.22
Time: 20:58:17
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 151458 km
Time Indication: 0
Date: 2005.02.12
Time: 13:04:34
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H11 0030
Coding: 0001026
VCID: 2A50B277F9DA
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H11 0030
Coding: 0001026
VCID: 2A50B277F9DA
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 A HW: 4F0 919 283 A
Component: Parkhilfe 8-Kan H12 0030
Revision: 06.00.55 Serial number: 00067811820507
Coding: 0001016
VCID: 22405A5781EA
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
  craigyb said:
Looks like a straightforward amp fault to me. And as you have said you have an Avant, have you checked the left side of the boot for water damage behind the MMI access panel, ususally looks like white staining on the silver MMI parts.
Many thanks for quick reply.
The fault started a month ago during very dry weather so I would be surprised if it is water damage, but will check tonight. Is the "amp" the part number 4F0 035 541 B? Sounds expensive.
  craigyb said:
The water comes from your rear wash wipe pipe, so wet weather has no impact. Check the rear wash wipe functionality.
541 B is the radio, amps usually end in 223 or 225 and is the top module in the rack in the boot.
Thank you. The wash wipe functionality is poor and in the process of checking it (as you suggest) leaks all over the amp. The w/w has always been ropey and I've just put up with it. I have now removed the amp and though it doesn't look too bad on the outside I guess that over time water has taken its toll inside. Time to replace it - are they repairable?
I would get the wash wipe pipe work repaired ASAP just in case you pull the lever again and poor more water in as you have the radio and DVD nav below the amp and it can get very expensive when all 3 are water logged.
Never tried to repair one, I should imagine water has done coonsiderable damage at a component level, so easier to replace.
You can buy second hand ones on ebay between £100-400 depending on if it is BOSE or not.
But you cannot install fully it as the amp has component protection, when you install it the sound will cut out on one half until CP is removed by a dealership. It may also need coding to suit your vehicle unless it has come out of an identical spec car. Things like, leather, engine type, RHD have to be coded into the amp.
It's a Bose one (4F0 035 223 A) so it will probably cost near the upper end of that bracket. I have a Vagcom but see that visiting the dealer may have to be done to remove the CP.
Thanks for all your help.
  craigyb said:
I found a BOSE amp for £120 on ebay a few weeks back.
I have fixed the wash/wipe pipework. The water had got into the wiper mechanism and messed it up although the motor itself worked and is just about fixable, but I shall renew it soon as I doubt it will last long.
As I couldn't see a BOSE amp for this model for sale online I thought that I had nothing to lose by trying to repair the damaged one. I opened it up and the PCB was badly affected by water damage. However I cleaned it all up with acetone and a small brush and it came up fairly well. I dried it out, put it all back and tried it out - no change. As if it were likely. However next morning it worked first time and radio, CD, Satnav, telephone etc all functioned perfectly. Wow. 3 days later all still well. A VagCom scan still shows a problem (as below) so I don't know if the VagCom is showing a false error or there really is a continuing problem. Hopefully I can now ignore it!
Wednesday,22,June,2011,21:35:04:29408
07-Control Head(High/D3)OK OK
77-Telephone OK OK
56-Radio OK OK
37-Navigation OK OK
Gateway Installation List: 4F0 910 468 A
02-Auto Trans -- Status: OK 0000
07-Control Head -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
37-Navigation -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Coding: 0011372
VCID: 1A3062B7A9BA
Coding: 0000001
VCID: 234E5F539EF0
Coding: 0020872
VCID: 2D5AB96BC834
Coding: 0000147
VCID: E3CE9F535E70
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 392CQ057514294
Coding: 0001002
VCID: 254A414B90C4
Part No: 4F0 910 609 B
Component: Bedienteil MMIC6H03 0010
Coding: 0001302
VCID: DBBEA7B36600
Coding: 0000101
VCID: E6C88647AD42
Coding: 00062736
Shop #: WSC 02335
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7136005
Shop #: WSC 00000 000 00000
VCID: 1C3C64AFA38E
Coding: 0013125
VCID: 27564B43EAC8
Component: Lenks‰ulenmodul H07 0230
Coding: 0102142
VCID: E6C88647AD42
Coding: 2049443
VCID: 2142555B84EC
VCID: 27564B43EAC8
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H44 1060
Revision: 00000000 Serial number: 305CS057578292
VCID: 3B7E87330640
Coding: 0001562
VCID: 29524D7BFCDC
Coding: 0000755
VCID: 2E58BE67C532
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 187
Mileage: 74034 km
Time Indication: 0
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H09 0240
Revision: PROD_01 Serial number: 00000000778878
Coding: 0000113
VCID: 254A414B90C4
Coding: 0001103
VCID: DEB8AEA77512
Revision: 00000000 Serial number: ò(S
Coding: 0001562
VCID: 29524D7BFCDC
Revision: C63C0030
Coding: 0000321
VCID: DDBAA9AB7814
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394CY057528628
Coding: 0000001
VCID: 3162A51BD40C
VCID: 234E5F539EF0
Coding: 0001026
VCID: 2A50B277F9DA
Coding: 0001026
VCID: 2A50B277F9DA
Coding: 0001016
VCID: 22405A5781EA
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007543929
Coding: 0010900
VCID: 2C5CB46FF32E
  • 6 months later...
I am suffering a similar problem, I knew my rear wash was leaking so wasn't using it but took the car in for service and forgot to tell them this time, they soaked the AMP etc. and it no longer works. (3.0tdi Avant )
They took out the amp and dried it but the mmi is not working, I have a blank screen, if I turn it on I get an Audi MMI display then it goes blank again (MMI high Bose amp, cd, radio and TV installed)
With a VAG COM optical loop test I get a failure on the 47 sound system Optical (all other electrical and opticals ok). I would like to have a closer look at the various modules, Can I remove and disconnect the components and put them back in without affecting the CP?
Any input appreciated, thanks,
Tony
I am quite sure that you can remove and disconnect the components and replacing the same ones without affecting the CP.
I know that there is now a recall by audi which covers the problem. Eventually when I had to take my car to the main dealer to reset the CP they told me that the recent recall allowed them to replace the amplifier (which had been soaked - many times) and they put a new amp in. As they cost nearly £800 new i was relieved. I suggest you call your main dealer to discuss.
  • 1 month later...
  • 1 month later...
Hi,
Have a 2006 Avant with a MMI fault , none of the lights on the panel by the gearshift light up and nothing will turn on. In the back the Navigation will light up and you can eject the disc. I ran a optical test on vag com and it says error in all columns, the only ecu I can communicate with is the Can gateway any ideas where I can start here ?
Hi,
Any sign of water ingress in the boot above the nav unit? My local garage bypassed the BOSE amp above the nav unit to diagnose. Everything worked fine then, albeit without any sound.
If you are based anywhere near east Yorkshire I know a garage who could help at a very reasonable cost.
:wq
  gti123 said:
Hi,
  • 1 year later...
Guys, just a quick one on this, my A6 2005 Amp was only working out of one speaker but the bass was fine across them all, I have replaced it with a unit via ebay but now I don't get any sound at all, is this now in Component Protection mode?
  • 11 months later...
i have the same problem,
well almost i have an 2006 3.00 tdi v6 sline SALOON
a couple of weeks ago i noticed the cd player sort of faded in and out which had never happened before
then one day the cd radio satnav etc wasen't working i don't know why but i wiggled the key in the ignition a bit and it came back on
i don't know if that was just coincedence becouse the next day it was all dead and hesen't come back on since
the display screen does come on if i press the volume button down as if to turn radio on
i get the logo with the rings and the audi mmi messsege but then it goes blank
the multi changer in glove box is still on i can eject and load the discs
the dvd nav drive thingy in the boot stil ejects and loads the disc as well
if anyone has any ideas or advice that would be  very much apriciated
thanks in advance
