4RingsDH Posted August 1, 2011 Report Share Posted August 1, 2011 Hi, i would normally be browsing the Audi sections being an Audi tech - however i have a 2008 320d issue. The vehicle starts fine, no issues - will run for around 4 seconds and then die. it will start immediately after and repeat its fault. Generic fault codes P3263 and P14A1 originally recorded the P14A1 returns after the error deleted and restart has occured. P14A1 translates to BMW code 4010 (AFAIK). It relates to 'Exhaust Gas Back Pressure Sensor'. I am unable to positively identify what P3263 relates too. I originally suspected a blocked DPF, as the symptoms reflect that being a possibilty. I will be returning to this vehicle tomorrow to investiagte further, however my diagnostic software (VAGCOM) will only allow me limited functions with the BMW software. Any help, thoughts etc will be greatly appreciated. Link to comment Share on other sites More sharing options...
shark_90 Posted August 6, 2011 Report Share Posted August 6, 2011 Hi Dean I would expect that to be a blocked DPF also, it certainly sounds like it from the symptoms and with that code popping up. If you need any help with it or removing the DPF on it, feel free to give me a shout. Cheers Ben Link to comment Share on other sites More sharing options...
4RingsDH Posted August 7, 2011 Author Report Share Posted August 7, 2011 Hello Ben, thank you for your post and offer of help. I will PM you. We returned the following day and disconnected the EGR to vent exhaust and the vehicle ran without stalling, hence a blocked DPF was diagnosed. I have since contacted DPF Cleaning who are performing their service on Monday 8th August. I am interested in observing this repair. Link to comment Share on other sites More sharing options...
vwcat Posted June 17, 2014 Report Share Posted June 17, 2014 I guess that fixed the problem? Link to comment Share on other sites More sharing options...
