Polo 1.4 CL No-one can find the fault
Aruba
Polo 1.4 CL. 5 door hatchback
APQ engine
1999
35,000 miles
Problem
Bad tick over and smells rich
Only doing 25 miles to the gallon
Plug black on no 4 cylinder
New parts
Plugs
HT leads
Distributor cap
Rotor arm
Throttle body
Various machines have failed to find the fault, so I took it to VW main dealer in Portsmouth who had it for 10 days and eliminated possible faults with:
Ignition system.
Fuel system. (injectors and their spray pattern. Fuel pressure)
Lambda sensor, emissions
Cylinder pressure check done all cylinders, all pass.
Including no.4 that also passed leakage test.
They could not find what was wrong and wanted to strip the engine to examine the valves.
I declined their offer (£££) as I cannot understand how it is a valve issue as it passes a pressure test and there is no noisy tappet to suggest error in no.4 valve clearance.
Any one got any other ideas I could try?
Or am I mistaken on the valve issue.
  • 2 weeks later...
At last the problem is solved.
It was two dodgy followers (hydraulic tappets) on no 4 cylinder, worn concave quite a bit.
replaced the lot for £85
Sounds good now. bloody shame the garages couldn't have found that with their plug in gadgets.
