ChrisBradburn Posted August 28, 2011 Report Share Posted August 28, 2011 The missus was going swimming this morning but the car wouldn't start. I ran VCDS on the car and got 4 fault codes on the steering wheel. Here's the full log. Does anybody have any ideas as it is bank holiday so no VW support. Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKD.lbl Part No SW: 03G 906 021 PP HW: 03G 906 021 AN Component: R4 2,0L EDC 000SG 4661 Revision: --H08--- Serial number: VWX7Z0H63N19L2 Coding: 0000072 Shop #: WSC 00682 210 92187 VCID: 7CFC7C06467B No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD Component: ESP MK60EC1 H35 0104 Revision: 00H35001 Coding: 133B400D09260003C81202EC902000823000 Shop #: WSC 01316 785 00200 VCID: 74EC54266E2B No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE Component: ClimatronicPQ35 130 1213 Revision: 00130023 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 6DDA41420D01 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000008594889 Coding: E5898F2700041500471400001400000000087F075C000100000000000000 Shop #: WSC 00000 785 00200 VCID: 336E973A2BA5 Part No: 1K2 955 119 E Component: Wischer 210608 021 0501 Coding: 00038805 Shop #: WSC 00000 Part No: 1K0 955 559 AH Component: RLS 030708 054 0402 Coding: 00209069 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: 38 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD23L0J8 Coding: 0013112 Shop #: WSC 01373 785 00200 VCID: 3D7AB1021DE1 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 CA HW: 1K0 953 549 CA Component: J0527 051 0101 Coding: 0000012 Shop #: WSC 01392 785 00200 VCID: 73EE573A6B25 4 Faults Found: 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent 00883 - Ignition Switch (D) Terminal S 012 - Electrical Fault in Circuit - Intermittent 00884 - Ignition Switch (D) Terminal X 012 - Electrical Fault in Circuit - Intermittent 01744 - Ignition Switch Terminal P (D) 012 - Electrical Fault in Circuit - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1K0 920 964 B HW: 1K0 920 964 B Component: KOMBIINSTRUMENT VDD 1212 Revision: V0002000 Serial number: VWX7Z0H63N19L2 Coding: 0003403 Shop #: WSC 00682 210 71757 VCID: 2C5C8C46F69B No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 Q HW: 1K0 907 951 Component: J533 Gateway H07 0062 Revision: H07 01 Serial number: 270608F2001036 Coding: E9807F060002020003 Shop #: WSC 01392 785 00200 VCID: 356AA92225D1 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1K0 920 964 B HW: 1K0 920 964 B Component: IMMO VDD 1212 Revision: V0002000 Serial number: VWX7Z0H63N19L2 Shop #: WSC 00000 000 00000 VCID: 2C5C8C46F69B No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 M HW: 1K0 959 701 M Component: Tuer-SG 006 1220 Coding: 0000692 Shop #: WSC 01392 785 00200 VCID: 3874A01632C3 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K0 909 144 C Component: EPS_ZFLS Kl. 69 2301 Revision: 00H15000 Shop #: WSC 01392 785 00200 VCID: 2A508A5EFC6F No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 819002005103087F2D04840570085FC690FCA0 Shop #: WSC 00000 785 00200 VCID: 830E87FABB85 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H08 9001 Part No: 1K0 951 178 A Component: Neigungssensor 003 0203 Part No: 1K0 951 178 A Component: Innenraumueberw.003 0203 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 M HW: 1K0 959 702 M Component: Tuer-SG 006 1220 Coding: 0000692 Shop #: WSC 01392 785 00200 VCID: 3972A51209C9 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No: 1K0 035 186 AF Component: Radio GR0 036 0034 Revision: 0003606S Serial number: VWZ2Z2H1161346 Coding: 0040400 Shop #: WSC 01392 785 00200 VCID: 6AD04A5E3CEF No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl Part No SW: 1K0 959 703 K HW: 1K0 959 703 K Component: Tuer-SG 006 1302 Coding: 0000144 Shop #: WSC 01392 785 1012552 VCID: 3874A01632C3 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl Part No SW: 1K0 959 704 K HW: 1K0 959 704 K Component: Tuer-SG 006 1305 Coding: 0000144 Shop #: WSC 01392 785 1012552 VCID: 3972A51209C9 No fault code found. End --------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
SAiLO Posted September 3, 2011 Report Share Posted September 3, 2011 Have you tried clearing the codes? Looks like the ignition is being cut off due to an electrical error in the circuit. Try clearing the codes and maybe disconnecting and reconnecting the wheel. Link to comment Share on other sites More sharing options...
ChrisBradburn Posted September 4, 2011 Author Report Share Posted September 4, 2011 We called the AA out in the end as Leicester Volkswagen wouldn't look at it unless we took it in. The AA were very helpful and started it up with a lot of easy start and then followed my wife down to the garage incase it failed again. It turned out to be a faulty ignition switch which was replaced under warranty. Leicester VW were very helpful once they got it in their workshops with several phone calls detailing progress. Thanks for your response SAiLO. Chris Link to comment Share on other sites More sharing options...
