adamski74 Posted September 9, 2011 Report Share Posted September 9, 2011 I've tried searching but cant seem to find an answer online so thought id post a message. I have installed my new MFSW with the SWCM (latest revision) and the slip ring (ending in B) and all is good! Controls on the wheel work a treat, coded the wheel and rns-e etc. I have the ABS warning light on the dash. When i go to the ABS section in vag com it sees the moduel, allows me to code it etc but when i go to try and calibrate the sensor using chanel 001 in basic settings i get an error message in red saying ERROR GROUP 001 NOT AVAILABLE? Any help appreciated. Adam Link to comment Share on other sites More sharing options...
adamski74 Posted September 11, 2011 Author Report Share Posted September 11, 2011 ok i think i have found something. i need to login to my steering wheel module i.e. 16 steering wheel. i've tried several login codes. anyone know how i find this? i have searched relentlesly. there must be a way to figure it out? this is the failt i get Sunday,11,September,2011,13:59:46:06588 VCDS Version: Release 10.6.4 Address 03: ABS Brakes Labels: 8E0-910-517.lbl Control Module Part Number: 8E0 910 517 E HW: 8E0 614 517 AL Component and/or Version: ESP8 quattro H05 0120 Software Coding: 0004526 Work Shop Code: WSC 06335 000 00000 VCID: 2952FA5BF969 1 Fault Found: 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 3 Reset counter: 40 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4222 Hex Value: 0x001E Hex Value: 0x3E93 Hex Value: 0x0001 Link to comment Share on other sites More sharing options...
adamski74 Posted September 11, 2011 Author Report Share Posted September 11, 2011 Sorted! Had tried everything before but it has to be done in a very specific way. Here are the instructions for anyone else that was having the same problem. It's the abs module you need the code for. [select] [03 - ABS Brakes] [Fault Codes - 02] [Done, Go Back] Start Engine (session still running). Turn steering wheel at least 30 ° left and back straight ahead. [Meas. Blocks - 08] Group 005 Field 1 (Steering Angle Sensor -G85-) Specification: 0.0 ° Tolerance (when straight): ±5.0 ° [Done, Go Back] [security Access - 16] Enter 40168 [Do It!] [basic Settings - 04] Group 001 [Go!] [Done, Go Back] [Fault Codes - 02] All fault codes should have disappeared. [Done, Go Back] [Close Controller, Go Back - 06] At last my mfsw now works perfectly! Now Bluetooth next! Link to comment Share on other sites More sharing options...
